Anybody use polyeurethane tranny mounts?
Discussion in 'The Garage' started by beastofablaze, Sep 13, 2006.
  1. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    I got all excited after I got my tranny mount from summit until I bolted it up... turns out my crossmember isn't level so when I went to tighten it up to the crossmember it pulled the metal out of the polyurethane about 3/16's of an inch. Is this supposed to happen? I noticed the stock tranny mount allows for that kind of movement but I didn't think the poly mounts would do that.:confused:
    Little help
  2. beastofablaze
    Apr 4, 2005
    441
    CA
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I run an Energy Suspension mount. There was no deflection of the mount wen I tightened it up. Did the metal rip out of the poly part?
  4. beastofablaze
    Apr 4, 2005
    441
    CA
    yeah but it's not cracked
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    If you have poly tranny mounts you need poly motor mounts as well...
  6. 1976Blazer76
    1976Blazer76 1/2 ton status
    Apr 17, 2006
    552
    Ridgefield, WA
    Don't mean to butt in, but I just opened up my new polyurethane tranny mounts not two minutes ago!!!:D
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    Do you have poly motor mounts???
  8. 1976Blazer76
    Apr 17, 2006
    552
    Ridgefield, WA
    I'm going too for sure absolutely, but don't even have the motor yet. I'll also have poly body mounts.
  9. beastofablaze
    Apr 4, 2005
    441
    CA
    not yet but I got paid today.... hehehe
  10. beastofablaze
    Apr 4, 2005
    441
    CA
    SO DOES ANYBODY KNOW OR AM I S.O.L.?
  11. merc359
    merc359 1/2 ton status
    Mar 25, 2005
    103
    Vancouver, BC. Canada
    Howdy,
    I pu the poly mounts on both engine and transmission. I didn't get the effect you are talking about. I am running a 4x4 and it uses the two piece mounts that bolt on the top and bottom of the cross member. When I was running the 2WD I also ran poly and I never had the steel more AT ALL in the mount. That seems odd to me...
  12. beastofablaze
    Apr 4, 2005
    441
    CA
    yeah i thought so too
  13. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    The Energy Suspention T mount didn't deform at all on my '91. I also have the poly engine mounts.
  14. beastofablaze
    Apr 4, 2005
    441
    CA
    hmmmmm... I don't know but I guess I'll run it and see how it goes.
    Thanks fellas.
  15. chevysmithz71
    chevysmithz71 1/2 ton status
    May 26, 2005
    1,464
    Kingsburg, Ca
    Did you atleast try to push it back in, if thats possible. If it does go back in I would run a washer for a spacer to level them back up when tighted down. Hope it helps.
  16. beastofablaze
    Apr 4, 2005
    441
    CA
    not a bad idea.
