anybody use this for d60 brakes??
Discussion in 'The Garage' started by sapper, Jul 20, 2004.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i have to rebuild the brakes on my dodge 60 and wondered if this would work, any input??
    brake kit
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    first guess is no.
    the brackets look like they will not clear the caliper without some grinding
    also the offset looks way off, the caliper mounts deep behind the spindle IIRC
    looks to be a scam, way overpriced, I paid $40 a side for my one off laser cut brackets
    in volume they would be very cheap
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    someone else had a link a while back on doing this. I'd search thatk30guy's post I know he was in on it.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I believe (could be wrong) that those are for people who want to use a 15 inch wheel on a Dana 60 without having to grind the caliper and I believe a while back there was someone on CK5 who used them (not sure of the results).
    It uses the stock caliper from your K5/K10/K20 instead of the monster D60 one that is why the offset is different than a stock D60 caliper bracket. My guess though that you would not be gaining much other than wheel clearance as you aren't taking advantage of the size of the D60 rotor/caliper combination. Although you are getting the D60 strength.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I was assuming a stock rotor
    IIRC there is a fair bit of distance between the rotor and the caliper mount
    the ones I have seen had an offset built into them
    never looked at doing it so perhaps there is another rotor that doesnt have as deep a hat
    the seller doesnt give ANY info, feels bad to me
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, I had a thread asking for some members to fab some of these brackets. I think TONYP was one who was looking into making some but never heard back from him.
    I think I'm gonna watch the eBay auction and see what happens. If those brackets don't sell for that asking price, I'm gonna e-mail the seller and see if he would sell them less if I could get a group-buy here on this site. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    just go to a laser cutter and have him cut them for you
    in any kind of volume they will be less then $10 each
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    True, true. I'm not real hesitant to spend $138 for a pair of brackets like those. I'd rather see our CK5 machinist members make them knowing I would be getting something that will work and fit the first time. I trust TONYP's products. /forums/images/graemlins/thinking.gif
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you could always contact cybrfire, he does a lot of lazer cutting.
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] yeah but if you could sell them for $100+ and make that much profit why not?
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    TSM gets closer to $300 a set
    and they do big volume so costs would be single digit per bracket
    retail is for suckers
  12. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    more than likely thos brackets are intended for use with a 1/2 ton rotor for a 5 lug conversion, they need to be offset to work with GM 3/4 ton 8 lug rotors,also the spacing on where the caliper bolts on may be wrong...those look exactly like the ones i have on my rig,i had to weld and re-drill the caliper holes and offset them by 3/8 to get them to work with 3/4 ton 8 lug rotors...pics in the dana 60 folder in my webshots
  13. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    I don't think those would work. I have JB's brackets on mine, and the caliper mounting areas are offset more than an inch inboard. I'm using 3/4 ton calipers and rotors BTW. I've seen brackets like those being used before, but they've been on 5 lug axles with chevy calipers and Jeep CJ rotors.
  14. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    mabey its worded funny and theyre actually for the back axel? /forums/images/graemlins/dunno.gif
