Anybody used this?? DIY Bedliner stuff
Discussion in 'The Garage' started by MTBLAZER89, Aug 3, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Looks like pretty good stuff. $80 a gallon for black doesn't seem to bad.
    Duraback
  2. Grim-Reaper
    7,385
    Atlanta
    Tough stuff. My buddy did his whole Bronco in it.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It works pretty good. Seems to be as good if not better than Herculiner. I'm going to put it on the top and bottom of the cab of my trail rig as insulation.
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Yep, did mine. You must prep per their instructions, and don't bother with anything that is not the UV protected version. The UV version is Durabak 18.
    It was very easy to apply, and had a much longer pot life than the literature stated - just added some xylene to thin it as needed.
    I put it on with a roller. Mixed the color from their blue, black with a bit of red. [​IMG]
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    how does the price compare to herculiner?
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    skigirl, how much paint did you use to do you whole truck??
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool thanks for the pics and info /forums/images/graemlins/waytogo.gif
  8. Skigirl
    Apr 2, 2001
    2,563
    About 2 1/2 gallons, but that gave me three coats. Could have easily done it with 2 gallons if I hadn't been mixing my own color.
    I thought there are similar products that have custom color options, tho I don't recall offhand who that was. The Durabak seems like pretty tough stuff tho. More expensive than Herc, but I think it's probably a better product.
  9. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I used Herculiner on the tub of my blazer. It is some seriously tough stuff, but don't rub against it. Mine is so ruff it will cut bare knees if your not carefull.
