Anybody using a Phoenix Injector.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mattman, Jun 14, 2001.
  1. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    Got a question. I have a 90 with the rear ABS brakes. I need to flush the brake fluid in it. I also have a Phoenix Injector (V-10 I believe, best $125 I ever spent). What I need to know, can I use the Injector to power flush from the master cylinder to the rear brakes? Will this mess up the ABS any? I've done this on my Bronco II and it is the easiest and quickest and least messy way of doing this but my BII doesn't have ABS so nothing could get messed up. Quick note, I believe power flushing is when you use the Injector at the reservoir ports and inject from a clean bottle through the ports and out the check valve at the cylinder bleed.
    90 GMC Jimmy, 350 TBI, 700R4, 32's
    84 Bronco II 204,000 miles and counting...........that's 206,000 and counting now
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    This post may help - sounds to me like there will only be tubing
    and no sensitive pieces in-line. (other than the wheel cylinders so dont go crazy with the pressure)
    <A target="_blank" HREF=http://www.coloradok5.com/forums/showflat.pl?Cat=&Board=blazer4x4&Number=134869&page=&view=&sb=&vc=1>http://www.coloradok5.com/forums/showflat.pl?Cat=&Board=blazer4x4&Number=134869&page=&view=&sb=&vc=1</A>
    Dave
    "Visualize Whirled Peas"
