anybody w/ square d-shaft?
Discussion in 'The Garage' started by Bhintz, Jul 29, 2005.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I want to get a square d-shaft for the front does anybody know if anybody makes these since I cant weld me making my own wouldnt work, or anybody on here want to make me one for some $$$
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    You know, i saw that 4x4 show on satellite tv making 1 of them the other day,
    purty frikkin slick. :bow:
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    No one that I know of builds them for retail. Here is a pic of mine that I built using a baler PTO shaft.
  4. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    maybe its a stupid question but why square?
    balzer
  5. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    they are easy to make and you dont have to worry about splines. square tube makes a very strong shaft
  6. mudnmyvayne
    mudnmyvayne 1/2 ton status
    Jan 13, 2004
    173
    Texas Panhandle
    Do they not bind up?
  7. primetime
    primetime Registered Member
    Jul 18, 2005
    22
    sa,tx.
    No, The Only Thing You Have To Worry About Is The Front Shaft
    Clearing
  8. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    It's hip to be square...
    Keep in mind that they are designed for slow-speed only such as rock crawling..... :bow:
  9. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I'm glad someone through that in this post!!! Oh and they are super easy to fix on the trail!
  10. mudnmyvayne
    Jan 13, 2004
    173
    Texas Panhandle
    so....no 7000rpm passes through a mud hole? :haha:
  11. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    609
    Hooper, Utah 84315
    The only benifit is easy to fix and they are cheap and thats why they are easy to fix they aren't stronger and they do bind but its more like they round off inside then get stuck together. They make a really good spare because depending on the truck they will fit both shafts
  12. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Very true when done the redneck way (mine). Another option to look into is splined PTO shafts. They're a little harder to find but I think a better overall option. (also more $$$)
    Although I can't really badmouth my square shaft, it survived two red-line passes through a mudpit last night, and landed me in 3rd place in the 35" and up class. :D
  13. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I could make you one but shipping would prolly cost a arm and a leg. :crazy:
  14. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    I think you forgot another big benefit, a lot longer slip travel. How do you figure they aren't stronger when your using thicker material? The one I have has never bound up and cost me about $20 to make.
  15. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    hell, Im sure it wont be over a 100 and Ill throw how ever much cash you want, think the job is worth plus the material, let me know
  16. kgblazerfive
    Dec 2, 2004
    10,620
    609
    Hooper, Utah 84315
    Yes if you use way thick stock they are going to be stonger but is the tube size is comparable then its not. If that was the case then ever input shaft or output shaft would be square tubing.
