Anybody Want a D60 $750 starting bid
Discussion in 'The Garage' started by ProJunkRacing, Dec 12, 2005.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I fail to see anything special...........
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well its got springs and and sway-bar, that alone is worth mega bucks :rolleyes: :haha:
  4. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    For my own clarification, if it is from a dually, do you have to change anything to make it fit right? I mean, those front wheels on a dually have a lot of offset.
  5. 1987Blazer
    1987Blazer 1/2 ton status
    Apr 9, 2005
    168
    Murrieta CA
    Yes, I have been told it is about 4" wider than single wheel. Hubs, stub shafts,lockouts, or use hummer 1 wheels recentered.
  6. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    In order to run the dually axle on the front, all you need to change is the hubs. Some people machine the lip off, but that could cause strengh issues. Just get a new set of hubs. GMPartsDirect has a hub & rotor combo for a decent price, as you will probably need rotors anyway.
    The bible on pirate explains it too.
    http://www.pirate4x4.com/tech/billavista/60_front/index.html
  7. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    well i am pickin up a 60 locally so i just wanted to post for anyone interested
  8. BudTX
    BudTX Registered Member
    Oct 4, 2005
    36
    Kansas
    Thanks for the tip.
