Anybody with a 90 350 and vortecs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Nov 2, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, I know what I want to do know. Just need advise or tid bit info.
    Im rebuilding the 90 model 350 in the truck know with the Scoggin Dickey Max-torque engine rebuild kit.
    COnverting to vortec heads with the TBI/vortec intake.
    and Im gonna need to get some headers with AIR, EGR, CBR, HE BEE GEE ARE, etc all that crap for the 90's stuff.
    Anybody else done this same setup (90 model) and all?
    I know alot of this is covered in lots of seperate posts. But has anyone dont all this as close to exactly as what Im doing?
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I've done it with an '89, but I am in Alabama and we don't need all of that AIR crap. Therefore, it no longer has any of it. What an awesome power combination! That truck will fry a set of 35's in 2wd. In 4wd it will sling some pretty incredible rooster tails!
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    What exactly is the AIR crap? And I thought that the EGR crap would be a tube running from the exhaust many to the intake? But when I look under the hood, the only thing I see is a flex hose coming out of the top of the exhaust going to the breather assembly. There is nothing else connected to the exhaust except for the 02 sensor.
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Also, what, if any, problems did you run into with the exhaust/headers as well as braket mounting and so forth?
  5. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    The AIR crap is the air injection system into the exhaust manifolds(come to think of it, I am pretty sure that GM quit putting this on the trucks in '88). The EGR on your truck uses a passage in the heads and a valve on top of the intake manifold to recirculate exhaust gas. The Vortec heads dont have this exhaust passage in them, therefore you can eliminate the system if you aren't governed by inspection laws, or you can buy an EGR kit to retain it. I am pretty sure that Scoggin-Dickey sell the kit.
  6. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    <a target="_blank" href=http://www.sdpc2000.com>Scoggin-Dickey</a>
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, the only thing we have up here in TN is a sniff check and they check to see if you have a CAT and the little flap in the gas tank filler tube.
    So, does thisessentially mean I can rib myself of all that crapola and not deal with the EGR?
  8. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Correct-a-mundo! Why spend the extra money to make something work that you don't need?
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Does the EGR setup, not reduce emissions though?
  10. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    According to Uncle Sam: Yes, but according to a sniffer test that we had done: No. We tested the old motor(in good tune) and tested the new motor, and the new setup was producing less emissions that the factory set-up.
  11. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    EGR seems to be more of a drivability issue then emissions issue IMO. I know Pace has everything you need for doing the EGR setup on the vortecs and manifold.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  12. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK... I just did this in Jedi Mind Trick...
    OK... if you need emissions you will need the do the following; there is an accomodation for and EGR valve, but in order for it to get the oxygen to measure you have to run a pipe from the manifolds / header up into the intake so the EGR valve can read it... I just blocked this off because in WY I don't have to mess with emmission...
    matter of fact, I've got the emissions pipe with all the adapters needed sitting here new, and I'll sell them to you for half of what you can get them new + actual shipping cost.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  13. GMtrucklover
    GMtrucklover Registered Member
    Oct 29, 2001
    75
    colo spgs, co, us of a
    Ftn In summit i magazine eldelbrok just came out with an intake manifold that allows to keep you egr. On my 90 sub tbi when the egr went bad the truck ran like crap and got horrid mpg's. you would want to keep that system. But every thing else should swap over. You shouldn't have air injection, That was stopped in 87 or 88, i think my burb doesn't have it, even my 87 had it but after talking to emmision tech he told me that air was optional in the state of co and not manditory. Might be so in your case. headers would be sweet just remember to keep you O2. It should be easy now picking out your headers and remember you egr doesen't touch your headers.
    74 gmc work truck
    87 k5 blazer hardcore wheeler
    90 suburban family hauler/snowmobile
    96 gmc k1500 daily driver/tow vehicle
