Anyone broken a conversion u-joint?
Discussion in 'The Garage' started by mikey_d05, Oct 21, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Making a list of things I forgot to pack in my trail truck for this weekend's trip and realized that I don't have a spare S44-1350 joint...the rearmost joint in my driveline.
    Anyone broken one? What circumstances? I'm already short of cash and the diesel bill from this weekend sure isn't gonna help....should I shut up and pick one up or is it reasonable to go without one?
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I haven't broken my conversion joint....yet. I am sure one of these trips I will. Does Gilbert have a good parts store like Napa? If they do, then you might be able to risk it. But you'll lose valuable wheelin' time when chasing down parts. ;)
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Yes.
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    care to elaborate? circumstance, tire size, how heavy your foot is?
    It'd be much appreciated.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've been running the Napa version for years on my truck and never broken one, worn some out from poor angles, but never broken one. The K5 has been a trail-only rig since the 14FF has been installed but made 150-250 mile roundtrip on pavement at least once per month for several years.
    Originally it was a welded 14FF with a l/s equipped 3/4 ton front on 35's, and then a locked D60 front with 38's. I've broken two 10-bolt axleshaft u-joints (Spicers) and two D60 30-spline front stubs and a necked down inner shaft all at different times, but never the 447 conversion u-joint.
  6. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Sand drag track. 33" BFG AT. Hit gas at line, boom.
    ZZ502 Crate motor... :D
    Had new driveshaft built with 1350's. Problem solved.
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    interesting, i ran a conversion joint from Napa when i got the new diff, wore out that u-joint in about 3 months,,,went the cheapo way, (autozone) and has been on there ever since, about 2.5 years now. :D
  8. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    what are all the size joints you have? i have an s44-1350 and a 1350 in the rear. i just bring a spare conv. because i think its the weekest link...
  9. 4xcrazy
    Oct 31, 2003
    9,471
    5
    honestly, i do not know anymore, the stock on the front of the rear shaft, whatever that is for a 1/2 ton Burb, and the conversion on the rear of the rear d.s. from a 1/2 ton driveshaft, to a 3/4 ton, diff...
    it's been so long since i have had to deal with it, i forgot what they were,,, :doah:
  10. PsychoticDeadGuy
    Jan 8, 2005
    753
    the stock one should be an s44. i would carry a spare s44 because that would be your weekest link.
  11. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Yep I have taken out a couple. I usualy eat up the bearings on the small side...the large side never has a problem. The joint doesn't see much angle since I run a CV at the tcase. Its just hard on those little joints running a welded 14bolt with 44" tsls.
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have broken everything in my rear driveline except that ujoint. I blew apart my NP208, grenaged the S44 ujoint at the case, ripped slipyoke ears & driveshaft ears, and dented the driveshaft. I did all this carnage all at the same time too. :D The conversion ujoint is the only thing that survived.
    Harley
  13. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Exactly!
    I have broken countless D44 parts.
    I have broken some D60 parts.
    I have broken NP241 parts.
    I have creased and "ground on" (abused) the driveshaft.
    I just busted the slip yoke (again, 2nd time), the S44 joint, AND the driveshaft slip yoke all at once- but the damaged OEM driveshaft and the conversion joint still survived.
    I run a crate 350, 700R4, 241, 35sp D60 w/detroit, and a welded 14BFF all on 40"TSLs.
  14. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I am retiring the 6 year old conversion joint as the driveshaft is now a "trophy"...
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Well, I ran it this weekend and it didn't break, so I guess they're alright :D
  16. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    hijack...
    Got any wheeling pics..?
    Hijack off..
  17. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Hopefully I will in a day or two, I don't have any good shots of myself since I was driving but one of the guys I went with is supposed to send me some soon.
  18. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I run the u-joint in the other direction. I forgot who I bought a CV drive shaft from on CK5, but it was made with 1350's- except for one little problem, I only ran a 10B rear- Figured, hey, what the heck right? at least I'd be ready for 1 ton later.
