Anyone busted a Dana 60 carrier?
Discussion in 'The Garage' started by sled_dog, Oct 30, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Well? I hear people say you should put a Detroit in a Dana 60 cause its stronger, I get that but who has really busted a dana 60 carrier? I'm converiding ditching the rear 14 bolt for a dana 60 to go with a lower gear ratio than 5.13:1.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't think it's the carrier, but more the 30 spline axles that are common in rear '60s that fail.
    Some guy at real truck challenge with a ramcharger broke one with 38" Ground hawgs which are more like 36s. /forums/images/graemlins/frown.gif
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thought was a 35 or 40 spline spool and of course axles to match
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I understand your want/need for a lower gear than what a 14FF offers but the problem with the standard diff. in a Dana 60 is that it only has one cross pin . That one cross pin puts a whole lot of stress on the open carrier and it usually wears the carrier in an oblong fashion causing major slop and eventual breakage .
    I have much more faith in a carrier that was designed with a four pinion cross shaft like a D/L or a P/L ....
    Tom
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    makes sense. I need to call Moser engineering and find out about 40 spline full float shafts. If I do go with a rear 60 I think its definetally getting a D/L or a spool, likely a spool.
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    You mean like this...
    The PO of my D60 busted it, but provided a new carrier in the box ready to go. Wish he would have gotten a 4.56 up.. LOL
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ring gear spacer is always an option, and they DO work, I've known many to use them sucessfully.
  8. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I have not ruled that out. /forums/images/graemlins/thumb.gif
  9. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Also on rear 60's ypu have to hog out the spindle for 1.5" 35 spline stuff to fit. This can be expensive. Also there would not be enough meat there to run anything bigger than 1.5" shafts without risk of spindle failure.
  10. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    Well, I aint the techiest guy on here, but I run a D60 rear mainly so I could use an ARB locker. I run 38 inch tires with 4.88 gears and beat the hell out of this thing. Ive had 0 problems so far...
  11. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    A friend with a crewcab dodge with 39.5" boggers broke the rear axles just turning off the street. He is running d60's front & rear with 6.17's ,detroits & sm 435 4 speed./forums/images/graemlins/yikes.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Heavy truck, deep gears, manual trans makes a detroit more like a spool, and big, wide tires.....hmm. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  13. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    And probably 30 spline axles. /forums/images/graemlins/doah.gif
  14. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    Yes it was the 1.31" 30 spline axles
  15. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    David - You know that Steve more than likely stressed those ahfts on a previous off-road trip and they just gave up at that time .
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Makes no difference, 30 spline axles aren't going to hold up to that in the long run is the point.
  17. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    My point is that they DID NOT break due to the strain of turning on the street .
    I am not saying that the small 30 spline stuff is the way to go by any means but the stress of normal street driving is not what caused them to fail .
    Tom
  18. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    I know the street didn't break his axles, I just stated that they broke while driving on the street. He actually abuses the truck and it did great dragging the burned out caddy at Jones swamp /forums/images/graemlins/waytogo.gif
  19. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    That was pretty cool !!!! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
