anyone buy a body mount kit from LMC?
Discussion in 'The Garage' started by **DONOTDELETE**, Jun 9, 2002.
    <font color="blue"> i know it uses rubber instead of poly but it seems like the most complete kit out there- all the bolts, washers etc. </font color>
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I would definatley like to know about this too......I need to replace my body mounts too.
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    In looked at those too, but already have a set of poly mount to install. LMC should make a kit of just the hardware as they sell poly mounts too. /forums/images/icons/wink.gif
  3. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    I haven't bought one yet(need too) but in the catalog it says it comes with everything(and the picture shows it too) to mount "as orginal" to you frame. you just need to call them for your specific truck. My catalog is for GMC Truck so I don't know if the part#'s will be the same.
    Hope this helps,
    Don
  4. tp85
    tp85 1/2 ton status Premium Member
    Mar 14, 2002
    130
    Maryland
    I recently bought the complete kit from GMCPaul. I believe that it is the same kit that LMC sells because the cushions had "LMC" embossed on the rubber. Paul charges more for the kit, but less for shipping. And Paul is great to speak with on the phone.
    If you want, I could give you a complete run down on the kit when I have more time to type. I am in the middle of the body mount job, so I have discovered a few things about the kit and frame/body rust at the mounting points on my truck. I'm goin to have to repair a few things before I install the new mounts. I was hoping that this was going to be a quick job, but no such luck.
  5. Grim-Reaper
    7,385
    Atlanta
    I just installed a set of Polly's in the 75. When I get around to them in the Lady's 79 I'm going with rubber. The polly's transmitt every bit of noise (no carpet isn't helping matters) the truck makes. I had a rough idle and a partly fouled plug and MAN you could tell a difference when I fixed it.
    Few other places to check for prices and what the kit has is www.yearone.com. Golden state. Kingparts. The links should be in the links post over in the second gen forum.
