Anyone changed a ignition lock switch before
Discussion in 'The Garage' started by Curtis2kul, Nov 29, 2003.
  1. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    Help, i have to change the ignition lock switch, i have got the steering wheel off but now i cant get to the screws to get it out, there is a plate that is in the way, its a steel plate that the steering lock (the lock that doesnt let your steering wheel turn unless the key is turned to on, etc.) how can i get this plate off>
  2. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    Go to the parts store and get a puller from them. I got mine from advance. It looks like a big "U" shaped thing with a screw that runs down the middle and has 2 round adapters that go with it. I'll take a pic of it tonight when I get home from work.
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    It's called a lock plate depresser. It depresses the lock plate so you can get the clip that holds it down off...
    Rene
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    thats strange....... i've done this before and we never used one of those fango dango tools, we just used a hammer and some screw drivers and pressure. /forums/images/graemlins/rotfl.gif
  5. Curtis2kul
    Oct 15, 2002
    62
    thanks for the help guys
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ive done it with a c-clamp too..
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you want to use the tool so that you dont mess up the clip, do not bend it or twist it or it might not retain the plate, it is spring loaded by a spring around the column shaft just under the plate, get the tool they are inexpensive, i always use my stepdad's one from his garage all the time,
    once you have plate remove it wil be easy to replace cylinder lock
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Once you have the right tools, it's about a 15 minute job. /forums/images/graemlins/thumb.gif
  9. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I made the tool out of a flat piece of plate with the two holes drilled in it at the right location and then used two sockets , 7/16 size worked well, between the plate I made and the lockplate,,,,
    I had my steering wheel lock jam and I just had to take the column apart.... so Im right where you are
    cam
  10. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I paid $8 for my lock plate depresser...how much is your time worth? /forums/images/graemlins/ignore.gif
    Some things just aren't worth building yourself. A lock plate depresser is one of those things.
    Rene
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rene
    You can always get it at AZ and return it as its part of the loan a tool program.
    $15 takes it home, bring it back and return it.
