Anyone Converted Power Windows To Manual Windows Before?
Discussion in 'The Garage' started by 4wheelin4Jesus, Jun 1, 2005.
  1. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    I cant stand the power windows in my 78. I was interested what all would be involved in converting them to manual (besides buying the parts). Can anyone who has done this let me know what the process is, and how easy/hard it is.
    thanks.
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    need the window regulator for manual and the crank. then put new hole in panel and its done. just a bit harded than changing glass.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    whats the break in door years? 80 to 91? i'd love to go manual in my 87.. i'm betting 90% of em where power...
  4. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    thats it. the manual regulator will bolt (or rivit) right in?
  5. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    yes, it bolts right in quick and easy...
    its a lot harder going the other way though, wiring to run and all...
    so i WOULDNT pull the wires unless you are really sure you dont want power ever again.
    actually, i think the window crank goes though the same location as the power window switch, so you dont even have to cut a hole
  6. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Just get dors from an old truck. There are interchangeable I think. 73-88 pickups all had the same doors.
  7. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    It is so easy to go manual from power you will laugh :grin:
    There is no need to change doors , pull the power reg. out drop the harness , bolt in the man. crank , put a big plastic washer over the pw. switch hole and you are good to go (or replace the door panel if you have one)
    There is nothing hard about it but to get the pw. reg. set up out of the door , it's a pain but can be done , I did it on an 85 1/2 ton
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I converted my '90 from power to manual by simply removing the power window motor/regulator assembly and installing a manual window regulator. All the holes are in the door, but I don't know about the trim panel because I don't run them.
  9. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    I did this on my blazer it's an 87 i used regulators from a 79. Everything lined up, the crank came through the window switch hole. It took me about an hour to remove/install everything. very easy swap
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Ha...I have manual windows and locks and want to go power. :p: :grin:
  11. Brian_D
    Brian_D 1/2 ton status
    Sep 10, 2012
    427
    Denver, CO
    oh hell yeah, im doing this.. i hate power windows. :woot:
  12. phreddei166
    phreddei166 1/2 ton status Premium Member
    Jun 21, 2007
    366
    Mass-hole !
  13. Brian_D
    Sep 10, 2012
    427
    Denver, CO
  14. Deuling
    Deuling "Official CK5 Post Whore" Premium Member GMOTM Winner
    Dec 8, 2010
    23,944
    2,627
    Muskegon Michigan
    Zombay thread! Oh and manual windows all day long
  15. Babaganoosh
    Babaganoosh 1 ton status Premium Member GMOTM Winner
    May 30, 2007
    10,196
    2,323
    Phoenix Arizona
    why do you guys like manual windows so much?
  16. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    they work..
    KISS
    sheesh, this thread is ancient.. i did my K5 ones like right after this thread, like 6, 7 yrs ago..... keeping the power ones in Mutt tho.. but ditching the power locks.. those i hate ALL the time...
  17. Brian_D
    Sep 10, 2012
    427
    Denver, CO
    ^ less chromey knobs as well
  18. Babaganoosh
    May 30, 2007
    10,196
    2,323
    Phoenix Arizona
    So can power windows. :dunno:
    I prefer power windows but manuals are fine. When the time comes I would like to swap to powered.
  19. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    GM power windows in the square bodies are FAAAAR more prone to issues, than the manuals are..
    you can throw in, no wires into the door too...
  20. Deuling
    Dec 8, 2010
    23,944
    2,627
    Muskegon Michigan
    Power windiws need wires and motors and switches to work. Any one of those go bad and window no go down/up. My arm normally is in perfect working order and my windows go up and down every time I try them, even if theres no key in the ignition! :whistle:
