anyone do a hand throttle on std tranny??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCOOBYDANNN, Sep 7, 2001.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    my whole cab is torn apart right now so i figure ill start another project. Has anyone done a hand throttle on the 465 tranny. I know of a couple Heeps that have it but didn't ask any ??. I know they use a bicycle hand brake hooked up to a cable (what kind), and i suppose just run it through the firewall as straight as I can, and what can I do to keep it from chafing or getting caught on anything, cause I really don't want it to get caught when I'm on a trail
    You know who I am
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Have not done mine yet but have looked at alot of them. Rather than the brake lever you might consider the gear changing lever because it stays where you put it. This way if you ever do on board air you can use it to hold the throttle up for running air toos. When I run mine, this winter, I will go down the shifter and up the trans tunnel to the carb. I think this will keep it out of harms way the best and be a cleaner installation. In the mean time try using your E-brake to hold the truck till you can let out on the clutch a little and have you other foot for the gas, that has worked well for me.
    I thought I was wrong once,
    but I was mistaken
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I used to have one on my CJ5 - I used a vernier throttle off of a water truck, and mounted it to the gearshift.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I think the e-brake would work (if I had one) that is why i want to do the hand throttle.
    You know who I am
  5. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    "I used a vernier throttle off of a water truck"
    whats that????
    You know who I am
  6. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Venier is a company that makes heavy construction equipment. the handle he is talking about acuates the spray nozzles and/or pumps on a water truck.
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i need to get some more info but someone in my local group just put one on a jeep and it only cost $30 shiped to her door everything included and has a ratcheting style throtle[​IMG] if anyone is interested ill get the info
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  8. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    count me in on the interested, id like some pic too if thats possible.
    You know who I am
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i will get more info the ratchet thing mounts to the gear shift knob the cable goes down the shaft the out the fire wall and to the carb very easy setup ill see if she will get me some pics she also has a ox locker up front that she has been very happy with and has tested it at rubicon
  10. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    A vernier throttle is a knob that's mounted to the cable - turning it counter clockwise opens up the throttle, and locks it positive - there's also a little button in the center that allows either a quick open or quick release. pugsley.alloffroad.com
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Glenn has one:www.coloradok5.com/beast.shtml
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  12. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    thats Exactly what I want, whats his screenname so i can get some info.
    You know who I am
  13. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Thats mine, I used a BMX Brake lever with a return spring built into it. I had to make a bushing to mount it on the shift lever. The cable follows the lever down and through the boot in the floor and up to the throttle cable mounting bracket.
    The other hand throttle lever you are talking about in the Jeep is made by Rubicon Express, they have them on their site. I prefer one that moves and returns as I squeeze or release it.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <a target="_blank" href=http://depdogsk5.coloradok5.com>depdogsk5.coloradok5.com</a>
  14. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    thanks man, im gonna have too look into that
    You know who I am
