Anyone Done a Propane Conversion?
Discussion in 'The Garage' started by Indyblazer, Feb 21, 2006.
  1. Indyblazer
    Indyblazer Registered Member
    Apr 24, 2005
    35
    Indiana
    Does anyone run a Propane Conversion?
    Is it a daily driver?
    I have been thinking about doing a conversion this summer. The advertising says it gives you engine a longer life and puts less crud in your oil for about the same cost as gasoline.(Not counting the $1,000 to make the conversion)
    I use my 84 K5 as a daily driver (Because I think K5's are just plain cool) and to pull my fishing rig to the nearby lakes. The website I found that advertises a complete kit talks mostly about the benefits Offroad.
    Any Good/Bad experiences that you can tell me about will help me decide if a Propane Conversion will happen this summer. I certainly trust the "Colorado CK5 Brotherhood" much more than the website advertising.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I was prepared to make the conversion to propane when I discovered that finding motorfuel tanks is sort of tough. You can run 30 or 40 pound forklift tanks but they are only 8-10 gallons of fuel so for a daily driver you would be refilling a lot.
    Most of the bed mounted motorfuel tanks I have found are between 60 to 80 gallons..not pounds....gallons. They are huge and would take up a large portion of your cargo area. That is the only drawback that I found.
    Also, check ebay...I have found complete take off kits for as cheap as $150.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Poke around over on www.austink5.net There are a few guys over there running propane (and some of them are on here also).
