Anyone done this? (203 twin stick build)
Discussion in 'The Garage' started by lochenjons, Jan 28, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    I just got ahold of a shifter another user built for one of his projects. It looks very much like this write - up. I will be installing it within the next couple of weeks. Other people on this board have built this or similar setups for the 203 xfer case.
  3. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    What ya want to know? :D
  4. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Well first, to get the shifter out of the truck I probably have to remove the section of the floor that bolts on (I forget what its called) where the shifter goes into right? The PO put all kinds of stuff around it to seal it down, I'm not sure why, and now theres bedliner over it so its gonna be pretty much impossible to take it off. Do youthink I could jsut get away with taking the boot off and working primarily from underneath or what? To get the shifter out of the other truck (picknpull) I took that section of the floor out and it was pretty easy taking it out
  5. CB77GMC
    May 6, 2005
    771
    Heath Springs, SC
    If exhaust is not in the way you should be able to.
