anyone done this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MUDNUTT, Nov 11, 2001.
  1. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    me, chevyracing and 4 or 5 other trucks are going to do some mudrunning on the 25th. im thinking of welding the rear diff and possibly the front also(its just a 10 bolt and i have an 8 lug ready to replace it) in preperation for this. anyone who has done this have any tips or suggestions.
    <font color=blue>DRIVE IT LIKE YOU STOLE IT[​IMG]
    <a target="_blank" href=http://community.webshots.com/album/24975635VazeJOnxiI>SEE MY PHOTOS</a>
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I've done it, it works. It even lasts. Just remember though, it is now a full time locker. You will burn off your tires a lot quicker, and cause premature wear on driveline components. If you must use 4wd on the street, unlock 1 hub or you will hate yourself. And remember this, you will not be able to turn corners fast or you will hop, hop, hop around them because of the locked rear end.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  3. MUDNUTT
    Aug 1, 2001
    339
    Mn
    thanks for the info. when you welded it did you weld the spiders to the case or just to each other?
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Spiders to eachother
  5. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    Cut a small piece of 1/4" stock to fill the hole between the spiders and put a bead around that also. It will add a lot for strength to the weld.
  6. seattlek5
    Feb 23, 2001
    311
