anyone else experience this?
Discussion in 'The Garage' started by pismorat, Jul 6, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I seem to be tightening my left front wheel bearing often. It loosens up when I am driving on long trips. Then I can feel it wobble when I drive straight or turn left or right from there on out. When I tighten it I make sure the tire(33") is on so I can feel the slightest movement(leverage). Any ideas on how to stop this? Thanks. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/truck.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    do you have the lock ring and the outer nut??? Sounds like something is missing. The lock ring that has all the little holes in it and the inner nut has the little post on it. They are all keyed so things can't loosen up then the outer nut holds everything in.
  3. pismorat
    Oct 29, 2002
    540
    California
    Yeah, I have the tightning ring, the lock washer w/ little post, and the lock ring, it's all there. Could the bearings just be bad? It doesn't look like it. /forums/images/graemlins/thinking.gif /forums/images/graemlins/truck.gif
  4. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    wow thats weird what torque r u going to ?? and try to get a new lock ring next time no matter what and
    replace the bearing and RACE's as they might be "honed" out from the abuse
  5. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I hope some-one has a good idea on this cause I'm having the same prob. with the right front on my D60. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    The torque spec on the outer nut is super high. Maybe 170 ft-lbs? Are you sure you're getting it tight?
  7. pismorat
    Oct 29, 2002
    540
    California
    I never check the torque rating, but if you go too tight, isn't that bad too? I think I only get it to about 100'lbs. if that, I just use a breaker bar. /forums/images/graemlins/truck.gif
  8. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    I think my book said 80lb-ft. I was having trouble with my burb too (might still, haven't checked in a while). I had a sheared pin on the inside nut. make sure the pin is going in to one of the holes on the lock ring. It might even be worth cleaning the threads, and putting a dab of locktite on the outer lock nut when installing it.
  9. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    could possibly not be tightening it enough but after the first time i would have replaced bearings and races and that probably would have fixed it....do it with the wheel off next time...
