Anyone else have this problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Aug 30, 2001.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Okay.. it's been raining cat's and dog's here.. And since I did my axle swap.. my truck won't fit in the garage anymore.. So.. here's the problem..
    It actually stopped raining for awhile today.. so i got in to start up the truck.. but the front carpet's are soaked.. just the driver/ passenger area floorboard's.. I'm trying to determine where the water leak is coming from.. and if anyone else had this problem?
    What's the fix..? where to look? what to do?
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Windshield seal...........Dan
    If it ain't broke.......Don't fix it....
  3. sluggo45acp
    sluggo45acp 1/2 ton status
    Jan 2, 2001
    472
    Northern fortress, Republic of Texas
    Yeah I had the same problem then remembered the top was off.[​IMG] there was about 3" of water standing in the floor, now ive got drain holes and no carpit.
    sorry no help on your problem
    Later
    Butch
    [​IMG]<font color=blue>Just because im paranoid doesnt mean there not out to get me<font color=blue>[​IMG]
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Its probably your vent windows. I know mine leak when it rains here. I dont have to worry though, not much rain. Try replacing the weather stripping on the and on the doors. Mine leak a little to. You can get the seals from thr dealer or LMC. About the same price either way.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  5. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    this used to happen to me. try pulling up the carpet and check for rust. that happened to me in the rear, then i welded the hole. andits all good.
    but now my passenger door seal leaks some times
    does anyoen know how to remove a seal from another blazer and put it on mine? thanks
    <a target="_blank" href=http://confederate9.coloradok5.com/>confederate9.coloradok5.com/</a>
    <font color=red>K5: Because size DOES matter</font color=red>
  6. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    mine was the topper an the door rubber
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  7. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Yep, my seals were good, but the w/shield frame had rusted through, leaked like a sieve.
  8. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Rocko, I had the exact same problem. I had a rust hole around my windshield but I sealed the entire thing with silicone. It still leaked though and my driver and passenger floors would still get wet. I found out the problem is with the passenger side rocker panel vent (near the floor). There is a seal that goes around it that lets water in. I am going to make a seal/gasket for my passenger side and that will cure the problem. I wanted to fix this before I put my new carpet in. Does this make sense? Let me know.
    "Constipated people don't give a crap!"
  9. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    BigTex..
    i believe that made sence.. I'm going to try and pinpoint it..
    I know on the older Blazer's.. there were Fender to cowl seal's.. wonder if mine has them...
  10. BigTex
    Dec 27, 2000
    974
    South Texas
    Rocko, mine had them and I pulled them out when I repainted my firewall. I forgot to put them back on when I reassembled the front clip. I thought that was the problem, but I'm not so sure. I just tested it by running water outside of it. It doesn't look like that would have fixed it, but who knows. I just didn't want to tear apart the whole front end just to put those seals back on, but I may have to in the long run. New ones are kind of pricey, though. Let me know how it turns out.
