Anyone elses doubler hit the tub?
Discussion in 'The Garage' started by 8_YOUR_H2, Jan 25, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I just installed a WMS doubler in a 1978 Chevy Truck. It seems that the tail portion of the 205 is hitting the tub and I have had to reinstall the 3" body lift for clearance. This is not clocked, both tcases are in their stock locations. The vehicle has a bench seat and I may scrap it and go with buckets so I can modify the trans tunnel but I am wondering if anyone else has this problem?
    FYI...the wms doubler is very nice as is the Northwest Fab shifters. Quality products.
  2. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    ya, but only eeded a 1 inch body lift to clear it.
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Not clocked with a 3" bodly lift and its still hitting doesn't sound right.
    But I would modify the tunnel as you probably are doing right now.
    I will be cutting and clocking mine so I can flat belly this beast as much as possible.
  4. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    Here's mine, just cut a huge hole in the floor and it will fit. I have no body lift, hate body lifts.
    Flat belly beast:
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    You mean like my ORD doubler did too
  6. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    It looks like my doubler adapter is hitting right behind the cut out for the shifters so I will hack the tub before I put in a BL. Thanks for the pics.
