anyone ever build one of these?
Discussion in 'The Garage' started by wraenking, Mar 8, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    http://www.truckspecialties.com/hitch_rack.htm
    i have some angle iron and i want to practice on the new elder more. my brother has one and its perfect for those days i dont want to be on the boat but want to drive out on the beach and do some surf fishing.
    ideas
    pics
    thanks
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    a worker at my dads shop made one out of just scraps of angle iron and expanded metal. it came out real good for not spending any money on it. he copied that picture more or less
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    My dad built one for his S10 blazer out of a piece of 2" tube and some angle. He also built a lockable plywood box on top of it, with a removable shelf. He uses it to pack gas cans, chain saws, and other things of that nature he doesn't want in the cab. He had to build up a couple of welds and grind them to the right shape to "shim" the tube inside of the receiver and take up the extra slop so it doesn't flop around.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I saw one version of that where it had a draw bolt like the gooseneck on a bicycle. Slide it in, push the pin thru, tighten the bolt to take up the slop.
  5. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I think it's Harbor Freight that offers a hydraulic lift like that, so you can easily load up to 500 lbs. into your truck!
    I would play with it too much.:blush:
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    My brother and I built one for his Jeep... We used 1" square tubing with some flat 3/16" for under bracing. It has sides on it similar to a roof rack.... No pics, but I can try and get some.
  7. dyeager535
    26,982
    191
    I *believe* Cabela's sells these things for a real good price...
    hitch haul
    Same size, half price, carries double the weight?
    Anyways, for that price, unless I had ALL the metal around, it wouldn't be worth making. Even if you have the metal, your time and tools have to be worth that price!
  8. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I have an aluminum one. Same size, same weight rating, less than half as heavy. It makes taking it off and on a piece of cake.
  9. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
