anyone ever make a TBI intake fit a non TBI engine? *NEW Q *
Discussion in 'The Garage' started by uglychevyZZ4, Apr 14, 2004.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i have heard that they can be adjusted to fit??
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Re: will 1990 sbc 350 intake bolt on a 77-80\'s block ??
    The '90 intake will be for TBI heads. Some of the bolt holes (can't remember which ones...I think all the ones except for the corners) will be at the wrong angle for earlier-year heads.
    You'd have to re-drill the wrong holes at the proper angle and then machine the surface where the bolt head touches to be perpendiclar to the hole (or use an angled washer).
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Grrrrr... the head bolts have to be chenged?
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    you may be able to modify the intake to fit. it is the center pair of holes on both sides of the intake that will be missalinged.
    most people (including myself) do the opposite, and fit an old dirty cast iron intake on a TBI block. good luck
  5. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I changed to a more appropriate name, maybe someone has done this. I hate quadrajets, period! I know tBi inside n out and want the non-boggin game on, besides, I can tweek TBI to be pretty gnarly and dont wanna change blocks if possible.
  6. heavy4x4
    Aug 28, 2002
    3,270
    Use TBI heads on your 77-80 block and the intake will bolt up fine.
    Or, better yet (maybe) is to use the old heads and old intake and make an adaptor plate to bolt the TBI onto the quadrajet intake.
    bigburban383 (or something like that) made one of these...maybe he'll chime in to tell you how it has worked so far.
  7. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Re: anyone ever make a TBI intake fit a non TBI engine?
    Ditch the OEM intake and buy an edlebrock performer intake (not RPM) $110. Then buy an adapter plate or make one like I did.
  8. dyeager535
    26,980
    It's the two center bolt holes that don't line up. They are vertical. The other 8 are at the same angle, so thats no problem.
    I'm sure you could grind the intake to the proper angle (or have a machine shop do it so you know it is flat) but I would have to imagine an adapter is just an easier way to go, all the way around, except of course swapping heads with the intake.
    Since the later heads are higher compression anyways (if talking late 70's-mid 80's SBC heads on yours now) swapping them with the intake might be your best bet.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That is very pretty piece there, good job. That idea sounds good. Would a TBI unit clear an EGR on an old intake (3 mount holes triangle base) if I wanted to do injection in the future on and older GM intake with EGR or on a Performer with EGR ? I know when I ran a borrowed Edelbrock carb for a few weeks that my EGR hit the edge of that Carb , and curious if TBI would hit also /forums/images/graemlins/k5.gif
  10. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    how does it work? awsomwe! looks like it also works as a good fuel heat shield /forums/images/graemlins/thumb.gif ignore th epm i sent, i found you /forums/images/graemlins/woot.gif
  11. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    i ground out the four center holes on the tbi intake to fit on the older 70'ish style heads then filled the gaps with gasket sealent, works fairly well. the other option would to get a newer beter flowin aftermarket intake with an adapter plate.
  12. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    so are the adapter holes just sitting over the primary holes in the intake? how does that work on a carb intake, ok? is it a dual plane or open plane?
  13. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Just modify the 4 center bolt holes...works just fine. My 79 has been running that way for over 3 years without a hitch. Have a spare manifold with no home..allready modified and ready to go..the 400 it was on died so i built an 87 up block for the chalet this time.
    DW
  14. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    got any pics of the mod up close? you used the stock tbi manifold?
  15. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ] /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  16. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    maybe a diff. routte, will a vette TPI 305 bolt to my sm465, and flywheel?
  17. dyeager535
    26,980
    What year?
    Not sure when Vette's first got TPI, but I know Camaro's it was '85. After that it would be new flywheel time, since '86-up was one piece rear main seal, which is a definite improvement IMO.
    Thats about the extent of hardware issues I can think of off the top of my head, wiring is a whole different ballgame.
  18. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    oops i meant " REMOVED FROM 87 CHEVY IROC CAMARO "
    it does have the harness, TG! is tpi way harder? so there is a flywheel to fit that with my 465?
  19. dyeager535
    26,980
    Yes 465's were used with the one piece rear main motors, and they are interchangeable with the NV4500 flywheel IIRC. (should be, Vortec's were pretty much the same engine)
    If it was a manual Camaro, then no issues with the PROM if the engine is transplanted into the truck. Key to keeping the swaps "simple" is to run all the stuff out of the car. If the engine thinks its in the car, it will run like it was in the car, and thats what you want.
    I wouldn't say TPI is "way harder", it just has more things to it. Of course, the gains are exponential. /forums/images/graemlins/smile.gif Once you understand the system it's not real complex...lots of wires, but sit down with a wiring manual, and you'll see it's not THAT bad.
  20. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    So if I get it you'll come down and help me wire & FIRE /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif for free BEER and food of course /forums/images/graemlins/thumb.gif
