Anyone ever pull the motor to do a clutch instead of dropping the trannie?
Discussion in 'The Garage' started by COCHEV, Feb 5, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    seems like less work to just yard the motor out then to drop both drivelines, the t case and the trannie and roll around under the truck all day. plus while the motor is out i could stuff in a cam /forums/images/graemlins/grin.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you wee doing a cam, maybe.
    but dumping all the coolant etc is a PITA and a lot more work then dropping a case and tranny
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I'd rather pull the motor any day.If you have a shop with trans jack and stuff it's a tossup,but,under the shade tree i'd pull motor.most of time the exaust has to come loose and all driveline stuff.I would rather have motor hanging than lay under all that weight too.88 SWB,SFA,on 38s /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Ive done it both ways, but now im gonna pull the motor whenever i need to. It is so much easier to have the truck down low and to stand up working on it. Crawling under it and jacking it up 3 feet is for the birds.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    What about the other way? Pull the trans hump cover and wrap a chain around the adapter and hang the trans/tc from a engine hoist.
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I did that when I swapped the auto for the 465....Made things soooo much easier.
  7. ZonkRat
    Jan 16, 2003
    1,003
    Did that with the 72,the floor don't come off in the 88 C K /forums/images/graemlins/thumb.gif
  8. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I've done it both ways: Pulled a tranny with a floor jack on an asphalt parking lot for one clutch job, Had a nice garage with a cherry picker and pulled the engine instead on a different clutch job. I'd rather pull the engine anyday, but mj is right, coolant and exhaust is a pita.
  9. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    What year did they stop making the tunnel removeable? My '73 is and my'70 was. /forums/images/graemlins/confused.gif
  10. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Auto tranny tunnels are not removable in the late 70's and all of the 80's. Manual tranny should still have a bolt on floor hump...
  11. ZonkRat
    Jan 16, 2003
    1,003
    88s not K5 ,CK 1500 SFA D60.None of them come off,Wish they did.Make tranny swap much easier later.Wanted to do doubler,but,Thinking bout 465 niw and mabey dblr later. /forums/images/graemlins/thumb.gif
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Only high-hump floors were ever removable. It was used with the SM465 (2wd or 4wd) and all 4x4s. About '81 or 82 they make it non-removable.
    I had an '87 truck for while. The PO (logging company) obviously didn't realize this until too late in the job. Looked like the floor had been opened up with a can opener, and folded back afterwards /forums/images/graemlins/tongue.gif
    Needless to say... I took the engine out of my '91 to do the clutch. Good opportunity to re-seal the engine. /forums/images/graemlins/thumb.gif
