Anyone ever put a chevy Th350 behind a 369 cadilac engine?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1bigk10, Jan 22, 2002.
  1. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    A chevy th350 behind a 369cadilac engine???? Does anyone know of an adapter???[​IMG] 1982 K5 Silverado. <img src=http://coloradok5.com/forums/images/icons/cool.gif> 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there are 3 diferent th350 bellhousings that i know of.
    1- chevy
    2- BOPC buick oldsmobile pontiac cadillac
    3- a combo of the first 2
    so i dont see a problem with it. of course for all i know a 369 is a 1912 motor
    formerly 77chev
    still a jerk though
  3. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Are you sure it's not the 368 Cad engine? Any BOP bellhousing bolt pattern will bolt up to it. Putting a Chevy T350 behind it will require an adapter plate (cost about$75) or you can swap the output shaft of the 4x version into a BOP version T350. Arte you aware that 368's are a POS and leak from every possible place known.
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
  4. Sparky87k5
    May 6, 2001
    726
    Are you sure it's not the 368 Cad engine? Any BOP bellhousing bolt pattern will bolt up to it. Putting a Chevy T350 behind it will require an adapter plate (cost about $75) or you can swap the output shaft of the 4x version into a BOP version T350. Are you aware that 368's are a POS and leak from every possible place known.
  5. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    You honestly have had problems with a 368caddy motor? Are you speaking of the 4-6-8 motors or the ones that actually work, without the 4-6-8 junk? I have owned about 4 of those motors and they have been the most reliable engines I've owned. I would chose the olds 350 over those motors because of simplicity thou and caddy parts don't come cheap. 1BigK10, even though I feel those are decent motors, I wouldn't waste my time with them. They are extremly heavy compared to many other V-8s of that size. They put out a max of about 145 HP and 265 FT/lbs. If you wanted to get a caddy motor go with the 500. [​IMG] Also I have all kinda of parts for the caddy motors if you need anything, including 368 motor with 40K on it. Good luck, Mike
    The jeep eater ......[​IMG]
