Anyone ever put a K5 on a UHaul......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Oct 8, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    ....car trailer? The logistics of the upcoming move are getting really rough. According to UHaul's specs it can't be done, but I'm sure that someone here has been willing to bend the rules a little so, is it possible?
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Matt (Baby Blue) has put his on a 2 wheel car dolly He said he had to remove the fenders (on the dolly) and it still just fit.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    If you have the full trailer it should fit if you back the truck on since the rear axle is narrower. My fuel pump died on the way to a weekend trail ride so we had to put my truck on one of my friends trailers which was pretty much the same size (I got to drive his custom suspension cherokee rock crawler on 38's for 4 hours, that was pretty scary!). The first time we got it up we realized it wouldn't fit so we had to pull it down and turn it around, then back it on... the entire time it was running on starter fluid that my friend was spraying in the throttle body while sitting on the fender. It was also on the side of the NY state thruway with traffic going by at 75. I hope I never have to do that again, talk about detonation!! I'm just waiting for my head gaskets to go any day now.
    Joe
    RIT Mini-Baja www.rit.edu/~bajawww
    Team Mudnuts www.mudnuts.org
  4. sluggo45acp
    sluggo45acp 1/2 ton status
    Jan 2, 2001
    472
    Northern fortress, Republic of Texas
    I hauled my parts blazer minus front fender with a nations rent car dolly. The front tires just barely fit I doubt it would have fit with the fenders on.
    Later
    Butch
    <font color=red>All that is necessarry for evil to triumph is for good men to do nothing.<font color=red><font color=blue>Edmund Burke<font color=blue>
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Cool deal[​IMG] I was concerned I'd have to go and find a set of factory Nissan tires/rims to be able to get it on a trailer.
  6. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Down south to Tucson - fun in the sun, Mexico, and an actual fulltime job[​IMG]
  8. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I think Rene might know a bit about towing a rig like that [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    I used a tow bar...which is fine for a stripped K5. Most car trailers are built too narrow for K5's though.
    Rene
  10. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    it can be done, o might master pugs, i have once trailered my 76 K5 w/ a 4in lift and 33's with a car dolley, might i add it takes a big truck and a good spotter. Just tell em you're pullin a maxima cause last time they wouldnt let me rent the trailer when i said i was towing the K5.
    phill
  11. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    i put mine on a penske trailer to do the tellico ck5 run in may. it barely fits, but it fits. my main concern was the weight, the trailer is rated for a maximum 4000#, and at the time the k5 weighed 4800#. tires on the trailer were lookin a little stressed but i had no problems round trip from florida.
    good luck!
    MTPockets
    <a target="_blank" href=http://coloradok5.com/moneypit.shtml>http://coloradok5.com/moneypit.shtml</a>
  12. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I hauled my Blazer from San Diego, Ca to Florida a couple of months ago. I used the car hauler and pulled it with their 24' truck. I had to take the boggers off and put on some street tires and it just barely squeezed on the trailer. I also had to air the tires on the trailer up to their max as it flattened the tires when I first drove it up on there. It made it 4 days and 3000 miles without any problems though.
  13. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    well good luck with your move pugs!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  14. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Thanks a bunch all!![​IMG] I went out to the rental places tonight and found out that Ryder's trailers are a little wider than UHaul's - 77½" at the front compared to 75"...So it looks like we'll be going Ryder for this move.
  15. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I know it takes all 83" of my trailer width on the front axle of my Jimmy. Make sure you pump the tires all the way up it will help to fit the truck on there. I hope you have 15x8 wheels or it will be tight even at the back.
    My .02
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  16. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Can you grab a set of rims from a junkyard, just to throw on the front in place of the tires? That'll keep hieght a little lower, and make it possible to secure it a little tighter to the dolly, i'd think. If you can get a tow bar, I'd sy that's the absolute safest bet...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  17. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Go to Nations rent or any large rental place (Places that rent large equipment) they have dollies that are quite wide, we have used a regular car dolly before, just put on some dinky lit'l tires on the front, or haul it backwards the wheel base is narrower.
    Still a very-pissed off
    White Knight
  18. english_bloke
    english_bloke Registered Member
    Oct 5, 2001
    22
    Just moved from England to the States
    Perhaps a tow bar would better suit you?
    Cheers,
    The English Bloke
  19. dyeager535
    26,979
    I had to put mine on a trailer. I popped the front wheels off, jacked the front axle up far enough for the hubs to clear the fenders of the trailer, and rolled it forward. (floor jack) once I cleared the fenders, I put the tires back on, and dropped it down.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  20. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I was thinking about that - I'm close to needing new tires/rims anyway, so I might switch to 33X10.50's on 15 or 16X8's to make it a little easier. Barring that, I might see about the temporary acquisition of a large flatbed this weekend, and tow the Blazer and Jeep with the dually.
