Anyone ever replaced their yoke seal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jun 24, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I thought my rear TC seal was leaking. After further investigation, the seal and the shaft of the yoke are clean and dry. But inside the u-joint area, the "crotch" of the yoke is very oily. Confirmed by the nice spray just above the joint on the bottom of the bed. So, I found a post on this site that said the seal could be replaced. Anyone ever done it? Is it just called a yoke seal? Is it a cap like a u-joint cap or more like a regular seal?
    85 GMC Jimmy, 305 w/TH700-NP208, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    If I'm reading that right, sounds like the yoke is leaking, not the yoke seal (I Don't know of any such animal, anyway) There is a rear out-put shaft seal that is on the t-case that seals to the out-side dia. of the yoke, but when that leaks, it's rearly slung around.
    So, The out-put yoke from the T-case to the front U-joint, has a end cap that is pressed in or welded in. I don't know of any way to reseal it. So as far as I know, replacement is the only option.
    Also, the U-joints can sling grease around too, Exp. the greaseable ones. The difference should be easily seeen.
    Twiztid
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I have replaced the rubber yoke seal behind the nut and washer on the front output of a 208. I have found that RTV behind the washer stops the oil from creeping out the splines.
    <font color=yellow>Steve Frisbie</font color=yellow>
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Ahhh, dudes taliking about the front drive shaft. If so disregared my other reply, I don't know much about the front out-put seals on a 208.
    Twiztid
  5. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Can someone explain how to replace that front output seal on a 208 ? Does the fluid drain when you take out the front driveshaft ? There seems to be a flange with 4 bolts right above the C/V joint. Do you take that apart to get to the seal ?
    THanks !
    Blake
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    When you remove those 4 bolts no fluid comes out of the T case.
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
