anyone ever run these axle ratios
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1BAD88, Feb 28, 2002.
  1. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    I just rescently fried my rear end in my blazer .I looked into a rebuild and it is way to much money for me right now so I bought a used axle and put it in my truck .But now my front axle is 3.42 and the rear is 3.73 .is this combo within a reasonable difference? has anyone run these ratios without transfer case detonation?what problems can this cause? thanks for any info...................running 33's on stock lift
    1988 k-5 blazer 5.7
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    BIG difference.
    Even offroad your rear wheels will be spinning more than the front making 4WD kinda pointless.
    Probably should not use 4WD at all IMHO.
    Dave
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>91 Blazer and Toys</a>
  3. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I say play in 2 wheel, you get almost stuck drop it in 4 and dig out, when you hit solid ground again back into 2. If ya really gotta play. Definitely stay out of 4 on any solid ground. Just my opinion.
    Pics at <a target="_blank" href=http://community.webshots.com/user/jlblmkh>http://community.webshots.com/user/jlblmkh</a>
    (Formerly heaj1)
    Swimmin like a rock, slingin like a stock, but not for long.
  4. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i agree. i ran the same way for a few months and did not have any problems cause i stayed in 2wd until almost stuck, then right back to 2wd.
    if you try to run in 4wd any distance at all on hard ground your gonna kill something real fast
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Well you could always run your 33"s in the back and 30" tires on the front [​IMG]
    But seriously. The difference between the front and rear ratios should be less than 10%
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    I once ran 3.23 up front and 4.10 in the back. I played in 2wd till I got stuck and if that was the case it was slick enough then that who cares if you spins faster, at least they spin. Only 2 times I put in 4wd to play, once in 2 feet deep snow to see how far we could go and once on really loose dirt hills.
    '86 GMC shortbox 3/4 ton
    <a target="_blank" href=http://www.picturetrail.com/mnorby>www.picturetrail.com/mnorby</a>
  7. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    No, I think everyone is correct. That is too big of a difference.
    On another note, I know some mud racers use lower gears in the front and higher gears in teh rear. This causes the front tires to spin faster, thus improved steering in mud and the front tires will pull slightly. Pretty cool huh?
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
  8. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Actually 3.42 and 3.73 are within 10% (3.42x1.1=3.762) ... I thought the diff was suppose to be more like 1 or 2%. Ten just sounds way too high to me.
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Yeah, 10% is way too much. Even uneven treadwear front and rear will make it run like crap on the road.
    But how about using a 203 T-case and just never put it in "lock"? Think about that for a while...
    <font color=green>Want to see a happy guy? Look at me as soon as my new wheels and tires arrive!</font color=green>
  10. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Nope.
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps
  11. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup 3.42 and 3.73 are within 10%
    I have always been told you can get away with 10% between axles if you keep it in the dirt. Wont work on the street.
    Mudders do it all time.
  12. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Put 32s up front and it will put it real close to the same effective ratio.
    86Jimmy 4"&35"s,87Burb 4"&33"s,69Firebird 525 hp,and 70GTO, 65 Howard V-drive PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My toys</a>
  13. 1BAD88
    Feb 23, 2002
    89
    bristol ct
    thanks for all the info I think I will run it like this for a while till I get my front ring-pinion to match .I really like the 3.73 compared to the 3.42 my truck launches off the line now and is great on the highway and improved gas mileage too......
    1988 k-5 blazer 5.7
  14. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i got a set of 3.73 gears for the front if he is interested.
    D44. i would have to pull them but i can do that.
    e-mail or pm me if he is interested.
    Grant
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rear wheels will spin SLOWER with lower gears, not faster.
    I would not lock it in 4 hi unless absolutely necessary. I had 4.10s in back and 3.08s up front and locked it in once because I was really really buried.
    Axles must match within 2%.
    Tim
  16. ca89blazer
    ca89blazer Registered Member
    Mar 2, 2002
    9
    Redding Ca
    I had 2.73 front and 3.73 rear and in 4hi it would just bind up. I have a friend who had the 3.42 front and 3.73 rear and a 203 w/ part time kit he said his truck never climbed as well and really liked that setup.
  17. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    True dat. My bad.
    Dave
