Anyone ever seen a "No Shim"GM Starter?
Discussion in 'The Garage' started by diesel4me, May 31, 2004.
  1. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    Anyone ever seen a \"No Shim\"GM Starter?
    I took my starter out of my 6.2 because it sounded like it was stripping the flywheel,and somtimes it wouldnt engage the motor,just spins--so I assume the starter drive is shot,and I'm going to replace it,the flexplate teeth dont look that bad,no broken ones at least,same with the gear on the drive,some wear but no broken teeth.
    When I removed the solenoid,I noticed on the casting of the nose where the solenoid bolts on are the words "NO SHIM" casted right into the nose---anyone ever see this before??.I've worked a parts counter for 20 years,never noticed one that says that before!Of course,there was one shim in it on the outer bolt I put there previously in an attempt to get through the winter /forums/images/graemlins/blush.gif.The starter is a recent Delco-Remy rebuilt.This has me confused /forums/images/graemlins/dunno.gif--all my motors manuals etc,have instructions on how to shim the diesel starter,now the starter says "NO SHIMS"!.Is it possible they mill the nose down when they rebuild them(doesnt appear to be any modification to me),and can I shim it if it still sounds crappy when I put the new drive in?.It sounds to me like the gears are still to far apart,and if that is the case ,then how do you correct that?,have the nose shaved down?.Any input would be greatly appreciated! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Re: Anyone ever seen a \"No Shim\"GM Starter?
    Never seen that, but i have never used the supplied shims when installing any starter, never had a problem with them either.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    1999 , must be something recent with replacement starters. /forums/images/graemlins/thinking.gif
    I have had only one starter ever need shims, on a 69 pickup and it wasn't mine, just worked on it for someone. I have had mostly small blocks and never needed shims. Must be luck /forums/images/graemlins/k5.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have never used shims on any of my GM starters. I have never seen "NO SHIM" stamped on any of them though. That is definitely different.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I've never used shims, even where I took the starter out and there were shims in it. But he is talking Diesel, I've never dealt with a diesel either.
  7. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I work at AutoZone and have seen NO SHIM written on some of the BOP type starters.
    Blake
  8. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    Thanks for the replies! K20,that site you posted was helpful--at least I know I wasnt seeing things!.Learning something every day!. /forums/images/graemlins/grin.gif
