anyone ever swap in a 6.5 turbo diesel drivtrain?
Discussion in '1982-Present GM Diesel' started by mpascino, Nov 28, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Debating drivetrain swaps, wondering how insane this would be.
    Thanks,
    Mike
    The jeep eater ......jeep it's what's for dinner[​IMG]
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    What do you mean by drivetrain swap.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  3. mpascino
    Jan 1, 2001
    557
    Connecticut
    sorry, had swapping in a 6.5 turbo motor in mind, and if I even got lucky enough to find a NV4500.
  4. BlueBlazer
    Feb 15, 2001
    1,940
    The motor will bolt right in. Id look for a 93-94 motor or a newer one that has been converted to mechanical fuel injection. The only problem I foresee is the turbo may get in the way of some things, especially if you have AC. Also get anything like glow plug controllers etc. from the donor truck. Are you planning on using the NV4500 and the tcase out of a newer truck or your present tcase. If you plan on the later, Advance Adapters has all sorts of adapters to mate up whatever you want. If you use the donor tcase you will have to get a front diff with a driver side differential. Im sure there are some things I missed but you get the basic idea of what is needed.
