ANyone ever thought about making their own flood lights?
Discussion in 'The Garage' started by Batmanjr, Nov 9, 2003.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I was wondering if it was ever thought of taking one of these 1,000,000 Candle Power spot lights and removing them from their portable cases and mounting them to a fixed location on one's rig!? Anyone ever thought of going that route for brightness? I've been researching cost effective ways to eluminate the trail! I'm looking for the most candle power for the dollar and these cheap spotlights come to mind... I'm sure I could put the bulb in a flood light housing and get a better effect than just a three foot circle of light.... I also found these:
    VectorBeam™ Technical Specifications:
    Model: 500 watt
    Lamp Unit
    Lamp
    Air cooled 500 watt short Arc Xenon Lamp
    Lamp Life
    >1500 hours (manufacturers warranty 500 hours)
    Beam Divergence
    1.5° - 5° standard motorized
    Beam Intensity
    10,000,000 Candle power evenly across whole beam, without hot-spot
    VactorBeam
    But I doubt they would be cost effective!!!!!! /forums/images/graemlins/deal.gif /forums/images/graemlins/thinking.gif
  2. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    no
    but i bet that no one would ever bright light you again.
  3. Batmanjr
    Mar 23, 2001
    1,537
    Yup, Two for the front, And one for the rear! /forums/images/graemlins/deal.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    if you do a search there was a light discussed. i think a tractor flood light from northern tools. this was a long tima ago but it was 9.99 it was a 100 watt light and had a black rubber outside if iirc. i want to say it was 5 inches but im not positive. all hell i look for it for you.
  5. Batmanjr
    Mar 23, 2001
    1,537
    I've got two of those but they really aren't that bright! I'm looking for daylight! I hated not seeing what I'm crawling over! I once had to crawl out of the rocks in the rain with the top off, and only stock lights.... It sucked so bad it was unbelieveable!!!!! I'm really just kicking around ideas, but couldn't you imagine two of those VectorBeam lights mounted on the roof of the K5!!!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/pimp1.gif
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    well i just found it but since you doont need it. those would be awesome but what kind of alternator would you ned to run em?
    few ideas
    find a trailblaxer light bar. (they are out of business but my buddies had 10 lights forward 10 back and 2 out each side.)
    find a jy that specializes in fire trucks ambulances, police cars ect. there is one in mccomb mississippi about 3 hours away. they have spots on everything out there.
    i will look when i go to drill this weekend and see whats the supplier on our spotlights in th coast guard. they are a great source of daylight /forums/images/graemlins/grin.gif gotta be cheap for the cg to use em we break the exspensive stuff /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    if you use the million power handhealds rig up a mounting thing and put a cig plug somewhere close. i think they run or charge off the cig lighter
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    if you have those tractor housing. do what you shoudl have done when ya first bought em. pop the stock light out and pop in a sylvania bulb #4509 it's a aircraft light that fits right in there, they are 100w bulbs with a 100,000 candle power. they also have a flood beam that is way wide /forums/images/graemlins/thumb.gif they are about $11 each.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    can you get those from any parts store?
  9. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I know knechts has em. /forums/images/graemlins/pimp1.gif
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    cool /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  11. Batmanjr
    Mar 23, 2001
    1,537
    Thanks Willy! I'll look for those!
    As for service lights, I can't use anything from the Army, it's all 24V and bright light scares the Army! /forums/images/graemlins/rolleyes.gif I'll try that bulb idea! What about repairing the reflectiveness? Can I use the crome spray paint?
    Also, Anyone got any secrets or tips on interior lights.. I put my CB antenna right where the interior light is and I want a better light anyways.... Thanks for the tips! /forums/images/graemlins/thumb.gif
  12. Batmanjr
    Mar 23, 2001
    1,537
    Who is knechts? Never heard of them! /forums/images/graemlins/thumb.gif
  13. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    how about the swivel map lights?
  14. Batmanjr
    Mar 23, 2001
    1,537
    I have an overhead center console that I could use, but hte mounting surface is flat and the roof is bowed... I'd have to make something work there! /forums/images/graemlins/thinking.gif
  15. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    we're oregon only, we just opened are 25th store.
    the light is a sealed beam assemble. so it has it's own reflective piece. are your tractor housings the ones like the peterson brand, like a rubber set up with a moutning tab??
  16. Batmanjr
    Mar 23, 2001
    1,537
    They have 5 pieces to them...
    1 A plastic screen that goes over the front.
    2 A Plastic ring that keeps the clear plastic lens in place...
    3 A clear plastic lens
    4 A plastic backing to the housing
    5 The glass housing that sits inside and holds the removable bulb...
    The bulb slides in and has a flat part that the two wires sit against... Kind of like the side marker lights.....IIRC /forums/images/graemlins/thinking.gif
  17. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    hmmm the housings I was thinking of are the ones off from petersen for tractors and they are about $5 or $6 bucks. come with sealed bean 55 watt bulbs
    poor spelling but I left it alone, kinda funny
  18. Batmanjr
    Mar 23, 2001
    1,537
    I would take pics but it's darker than crap outside.... Do you have a image of the bulbs? These bulbs are sealed too, but the housing is seperate from the bulb! /forums/images/graemlins/thinking.gif
  19. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    When did New Technology/Trailblazer go out of buisness? I just talk with them a year or two ago.....
  20. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
