anyone ever use Navy Jelly for rust?
Discussion in 'The Garage' started by MilpitasK5, Jan 21, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I used it under the floorboards for rust on my rig. Just wondering if anyone ever uses it here.
    I also just sprayed some on my axles last night to get rid of some rust.
    Also wanted to check if it can cause any harm.
    Thanks,
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    that was its intended use.......
    and still is as far as i know.
    i would use it if i had some.
    grant
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    It was kinda hard to find. Orchard supply had it but I had to find it myself b/c no one knew what I was talking about. After a 1/2 hour of asking around, I just went to the chemicals section and found some. /forums/images/graemlins/thumb.gif
    It's hard to find good help these days! /forums/images/graemlins/crazy.gif The people that work at our local hardware store don't know anything about anything. They always have a blank look on their faces when I ask for something like a Torx bit or even a U-Bolt...
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yup...used it on an old hay-wagon frame. Worked great. John Deere Green over the top /forums/images/graemlins/thumb.gif
    If you've got an Ace Hardware near you...go there. If the store doesn't stock it, they can at least order you some from the warehouse.
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I don't think you want to leave it on for a long time, as it might be hard to remove.
  6. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Really? I just sanded it down on my truck and then painted over it. Is that bad?
    Will it eat up the metal at all?
    There isn't one near by but I know I can find one somewhere around here b/c I've seen 'em. Thanks for the info., that's good to know.
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    I used to work on a boat and we would use it, we would rinse it off with water let it dry and then paint it.It should say on the can how to use....as long as you removed all of it the paint will stick. I bought a sandblaster for $40.00 that i use to remove rust, messy but get the job done.
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yep, I use it quite a bit, the stuff works great. You're supposed to rinse it with water after you wipe it off. Follow it up with some metal etch and the paint will stick like crazy. /forums/images/graemlins/thumb.gif </font color>
  9. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Home Depot here in Rochester carries it, or at least they did a year ago. (haven't checked since then)
  10. Storm Trooper
    Nov 24, 2000
    4,640
    I used it ounce and ended up throwing the toast away! /forums/images/graemlins/rotfl.gif
    Now I use Por-15 /forums/images/graemlins/smirk.gif
  11. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    Where did you get the sand blaster and what is the make/model?
