Anyone every put a Buick Big Block in
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazinzuk, Apr 27, 2006.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Might be getting a free 455 buick. Anyone every do this. I know BOP bellhousing but I don't know about motor mounts. Any other pitfalls?
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    if i remember correctly, the water pump is on the other side of the radiator for the lower hose, so would need a custom radiator. Exhaust is definately going to be tight and might need notching/ reinforcing.
  3. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    use the Buick
    Hell ya, do it. I have a '70 Buick skylark with a 455. A 455 Buick has awesome torque with pre-75 heads. I looked into this swap for my truck. For a stick you'll need a BOP bellhousing and a 455 only flywheel. If you're using an automatic I bet you could find a car transmission case and change the tailshaft. Other than that, the rest is just little stuff. You'll have to fab motor mounts, water pump outlet is on the same side as a chevy so you can use your radiator, the distributer is in the front, and Buicks are known for oiling problems. If you use the stock manifolds you should have plenty of clearance, but I don't think you'll have an other option but manifolds. Hope that helps. Kevin
  4. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    The motor came out of a chevy truck. it had been put there earlier by someone I don't know they used a BOP adaptor plate which I will probably use everything but the alternator is on the engine Including the flexplate and the plugs and everything. I will probably use the stock manifolds for now but might just build some headers for it. Thanks for the reply I can't wait to tear into the motor
  5. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    enigne mounts and the brackets for them that bolt to the block is what you need
    im sure ones from any olds or poncho or caddy or buick engine would work
    i may still have a pair of the brackets from a 350 olds from an 81 c-10
    not sure
  6. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    They are on the engine but thanks though
