Anyone fitted a Blazer rear tank into a shortbed pickup ?
Discussion in 'The Garage' started by ambritmann, Jun 22, 2002.
  1. ambritmann
    ambritmann Registered Member
    May 20, 2002
    23
    North Carolina, USA.
    Am looking to fit a single Blazer fuel tank into a shortbed pickup during the conversion I am doing from gas to diesel (both gas tanks are heavily corroded - need replacing), has anyone done this ?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yes, a friend did it.
    Fabricate some straps and off you go.
    -- Mike
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Just finished up doing the same thing to a stepside. We cut the blazer crossmembers out and welded them into the frame. The tank and skid plate bolted right in. We even swap the step side fenders from side to side and reused the filler neck on the passenger side to fill the tank.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That's on the to-do list of my cut down K30...
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    A friend of mine put a Blazer tank into a '72 K10 by using the existing rear crossmember and also another one that was mounted further forward.
    He had to move the stock rear X-member back slightly further to the rear to make the tank fit. He found another X-member exactly like the stock rear one and mounted that on the forward part of the tank while using the straps like the Blazers normally use.
    The setup looked very clean and worked great. He is still driving the truck today and has no complaints.
