Anyone get a shop quote on new valve seals?
Discussion in 'The Garage' started by K5thatShmobs, Feb 26, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Just trying to get a ballpark figure on what a shop might want to replace valve seals on my '89 TBI 350.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Valve seals are pretty easy to replace, if you have any desire to learn how to work on engines it would be a pretty good way to start. /forums/images/graemlins/thumb.gif </font>
  3. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    All you would need are some $20 valve seals and $50 in tools (valve spring compressor and maybe a spark plug air coupling). If you have access to an air compressor the job would be a piece of cake.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Even without a compressor it's cake, just use some nylon rope and stuff it into the cylinder to hold the valves up. I replaced my valvesprings using that method and it worked like a champ. </font>
  5. bowtiepower00
    May 11, 2000
    924
    AZ
    Yeah I've done it with and without, and it's not bad either way, I'm just an air tool whore... /forums/images/graemlins/smile.gif
  6. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    U beat me to it Shaggy.I've used the rope trick a couple times. /forums/images/graemlins/thumb.gif
  7. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I know this is a common problem that many on here have delt with. I consider myself pretty mechanically able, so I wouldnt be afraid to try it myself as long as I had a good guide. At the present time I dont have access to an air compressor, but this rope idea sounds cool.
    Can anyone recommend a good shop manual? Are Chiltons or Hayes any good with something like this?
  8. bowtiepower00
    May 11, 2000
    924
    AZ
    I have both the Chiltons and the Haynes, and I prefer the Haynes. I just looked through em both, and the Haynes follows this procedure in much greater detail (complete with pics). You might want to go to your GM dealer and ask to see the GM service manual for your truck. If you like what you see, you may want to get the real deal. They are usually much more in depth than the others, but cost somewhere around $75. The hard part for me the first time I did this was setting the valves when I was finished.
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Oh good greif if you know how to turn a wrench do it at home.
    Air is nice I have all the gagets for that but the rope trick works just as well.
    Go to sears and get a valve spring comressor, some rope and a lil bit of time and save yourself some $$.
    As far as setting the valves .. just do a search and and ya will get the picture pretty fast on what that takes.
    Everyone has their own methods of doing it and 2 billion posts can't be wrong LOL
    Just pick which one makes sence to ya and go to town, aint nothin to it but to do it.
    If ya aint sure about something ya have that gaget called a puter and there will always be someone here to help if ya get to a point where ya need a lil help.
  10. Mikeyg79
    Mikeyg79 Registered Member
    Aug 3, 2002
    83
    I bought a cheap valve spring compressor and used my compresssion guage hose, and replaced them (more like installed them) on my 84 in like 2 hours.
    Still not sure why I did this, just stops the oil from lubricating the valves.
  11. bluboti
    bluboti Registered Member
    May 6, 2002
    37
    west virginia --yes-us
    I checked the price at a couple of quality garages, thet want 400.00 to 600.00. So i'll deal with a little smoke at startup.
  12. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Hell, if you wanna drive to canada ill do them for 50 bucks CANADIAN! it only takes an hour and you can usually get away with using your valve cover gaskets again. and i just used a broken spark plug and a quick connect and made my own air chuck for holding the valves up.
  13. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    This rope trick, how exactly do you do it?
  14. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Get about 2" of 3/8'" nylone rope. roll the crank till it is down a bit and feed a bunch of the rope in to the spark plug hole.
    bring the piston up till it mashes the rope against the valves and walla.
    you can remove the springs and the valves will stay in place.
    remove the seal and install the new one. repeat on the next cylinder.
    tie a knot in the end of the rope so ya dont have to peel the head off to get the rope back.
  15. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Just verifying... so, like you said, 2 inches of 3/8" rope? Only 2 inches?
  16. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I think he means 2 feet. /forums/images/graemlins/ooo.gif
    James
