Anyone good at Laptop repair and diagnosing probelms?????? *updated*
Discussion in 'The Lounge' started by Emmettology 101, Jul 15, 2002.
  1. Emmettology 101
    May 9, 2000
    I bought an HP N5270. Whenever I load an O/S everything works fine, but then after a little wjhile a few keys quit working.... The keys that stop working are: q, w, e, r, u, i, o, p and the up arrow.
    Like I said when I load it it works fine for a while and then after I have it off for a little while after the initial load-up and playing around...
    Anyone with ideas? A friend of mine that is great with desktops said to try and clean under those keys...
    The thing that stumps me is that they work fine and then they stop...
    <font color="blue"> </font color> I just started it up this morning and the keys are working now. So maybe this is a problem after it gets started and warms up..??..??
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    Hartford, WI (formerly Etiwanda, SoCal)
    hmm... sounds to me like you might have a vacuum leak... have you tried to isolate any potential leaks, replaced the vacuum hoses, and adjusted the carbureator? next up, I'd try a compression test, and possibly a leakdown test....
    in seriousness tho, you could test the heat relation by leaving it on, and seeing if the keys stop working after a certain temperature is reached, or try keeping it cool, by running an auxiliry fan through some air vents, if it has them... the keyboard could have a loose connector, causing the keys to not work after a certain ammount of time (heat expansion causing the connector to loosten up) .... if your keyboard lifts out of the laptop, you might check and see if it has a connector you could tighten. if it has a keyboard input port on the back, you could see if an external keyboard has the same problem or not.
