anyone got a llink to Burb frame off resto pics
Discussion in 'The Garage' started by bassmannh, Jul 6, 2004.
  1. bassmannh
    bassmannh Registered Member
    Jun 8, 2003
    18
    I have a 91 burb with a bent frame from a hit in the right front wheel,You wouldnt believe it but it got hit so hard it snapped the steering stabilizer piston shaft, bent the right steering knuckle so bad it had 3" toe in!!!! also both spring shackles were bent one inch to the left, these were the stock shackles but in 91 the were 3/8" steel and the lower bolt is 9/16 x 5, (hd stuff), glad I wasnt behind the wheel when this happened. I bought the truck this way, I would like to get it back on the road, better yet the trails. I would like to get some info on frame off repair, straightening or replacement w/pics, any help or links greatly appreciated /forums/images/graemlins/dunno.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Taking the whole body off of a Suburban would be a pretty huge undertaking. Before doing that, I'd take it to a shop that specializes in frame repairs. You'd be amazed at what they can do with some big chains and hydraulics. /forums/images/graemlins/cool.gif
  3. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I think Skratch and Muddytazz have experience in this area...
  4. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    DOAH! /forums/images/graemlins/doah.gif
    I read this twice before I remembered I did stick a new tub on my rig a few years back /forums/images/graemlins/histerical.gif
    I must be loosing my mind.
    There are some pics in my cardomain link below, any questions I'll try to answer as best I can.
    But I helped a shop in Iowa stick the tub on mine with fork lifts.
    I've seen guys use pallets stacked up next to the tub to slide it off the frame and then roll the new frame in next to it to reinstall.
    Pulling the tub really isn't that hard.
    As long as all the wiring is undone from the firewall, bodymounts and taillight wiring, fuel fill hose . . .
    If you have a couple of A fames and hoists you could lift it up off easily and roll the old frame out from under it.
    If I ever do it again (very possible) I'll either do it that way or go back to the shop I worked with in Iowa, for the money it was worth the drive.
    It would be time consuming to swap all the driveline across to another good frame but if it's all good and the tub is too, I'd do it in a heartbeat. /forums/images/graemlins/peace.gif
    Oh yeah, page two is most of the body swap, and since your a heavy truck mechanic, look at page 8 and see if you think you might be able to fix my rig that I wrecked. /forums/images/graemlins/thumb.gif
    Then fill in the rest of your profile so we know where you're at, maybe one of us is close enough to give ya a hand too.
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    onetonburb did a nice little swap very cool way to do it, don't have the link pm mabey
