Anyone got any concrete working tips or advice?
Discussion in 'The Lounge' started by newyorkin, Sep 19, 2004.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I had an 80lb bag of Sakrete left over from a March project, and I used it last night in my bathroom floor to replace concrete I'd removed. I actually have been using joint mortar, but ran out at 11pm and had to use the concrete.
    Normally, the Mortar seems to be cured enough to walk on by the next day. This sakrete seems to still look wet, and I figured it would be ready by now. It still seems like if I walk on it, I'll mess up the finish at least. I shoved a screwdriver in it today, after 12 hours of curing, and it went in and broke up the concrete a little there. Does mortar just cure faster in general?
    I'm thinking I may have mixed the cement too wet. Is it normal for it to still be this soft?
    I'm kicking myself today. I should've just waited til I could go get more mortar today...
  2. 87_k5_silverado
    87_k5_silverado Registered Member
    Jul 23, 2004
    24
    Jim Thorpe, Pa
    quite possible you used too much water; hence the slow cure time.....you could just use styrofoam on the floor and walk on that. it won't mess up your finish. the krete should cure w/in 24 hrs.
  3. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    Haven't used sakcrete in a while but regular portland cement concrete will take 28 days to completely cure. What's the label on the bag say?
  4. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Concrete curing is a chemical reaction not a drying process. It should be cured enough to walk on after about 12 hrs. in 24 hrs it should be pretty hard. By 7 days it is about 50% of its design strength. From 7 to 28 days it keeps getting stronger, it's just that the cure speed reduces.
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    So did it cure yet Ratch???Or you still have a mud hole in the bathroom...? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I don't know, I got tied up in another prject and haven't been in that room to check it... Thanks for topping this, though, you reminded me I have to get more mortar if I hit Home Depot today.
    Home sick again...
