ANYONE GOT INFO ON PROPANE??
Discussion in 'The Garage' started by wild-will, Oct 8, 2003.
  1. wild-will
    wild-will 1/2 ton status
    Aug 21, 2003
    185
    Oak town WA
    Anybody here know if i could hook it up to my truck. like the prices and if i could do it myself?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    is the truck diesel? or do you plan to run it as the main fuel?
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
  4. wild-will
    Aug 21, 2003
    185
    Oak town WA
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Search the boards here too...I know I've discussed it a while back.
    What I can tell you is that prices are NOT good. The ACE where I work charges $2.75 a gallon...and that price doesn't fluctuate. /forums/images/graemlins/eek.gif
  7. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    propane is good in that it can run at any angle... but the fact that not all stations have it, that you have a high pressure gas bomb attached to your rig, and that propane doesnt have nearly the energy per (insert whatever volume unit you want here) as gasoline means you need more of the stuff to get the same performance. Just my opinion, but the negatives out weigh the posetives.
    j
  8. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    ProductName:
    Propane
    ChemicalName:
    Propane
    Formula:
    C3H8 4
    ChemicalFamily: Alkane (hydrocarbon) 1 0
    Use:
    Various
    Synonyms:
    Dimethylmethane, LP-Gas, Liquified petroleum gas (LPG)
    NFPA Fire: 4 HMIS Fire:
    4 Acute:
    No
    NFPA Health: 1 HMIS Health:
    0 Chronic:
    No
    NFPA Reactivity: 0 HMIS Reactivity:
    0 Fire:
    Yes
    NFPA Special Hazard: Mixture:
    No Reactive:
    No
    Sudden Release Pressure:
    Yes
    02. INGREDIENTS - COMPOSITION & INFORMATION
    PERCENT EXPOSURE GUIDELINES
    COMPONENT CAS No. (BY WT.) OSHA - TWA ACGIH - STEL
    Propane 74-98-6 99.0% 100.0% 1000 Simple Asphyxiant
    LD50: None. LC50: None.
    03. HAZARDS IDENTIFICATION
    EMERGENCY OVERVIEW:
    Warning:
    Flammable liquid gas under pressure.
    Can form explosive mixtures with air.
    May cause frostbite.
    Potential Health Effects Information:
    Routes of Exposure:
    Inhalation:
    Simple asphyxiant. It should be noted that before suffocation could occur, the lower
    flammability limit of propane in air would be exceeded; possibly causing both an
    oxygen-deficient and explosive atmosphere. Exposure to concentrations (> 10%)
    may cause dizziness. Exposure to atmospheres containing 8-10% or less oxygen
    will bring about unconsciousness without warning, and so quickly that the individuals
    cannot help or protect themselves. Lack of sufficient oxygen may cause serious
    injury or death.
    Eye Contact:
    Contact with liquid or cold vapor can cause freezing of tissue.
    Skin Contact:
    Contact with liquid or cold vapor can cause frostbite.
    Chronic Effects:
    None.
    Medical Conditions Aggravated By
    None.
    Overexposure:
    Other Effects Of Overexposure:
    None.
    Carcinogenicity:
    Propane is not listed by NTP, OSHA or IARC.
    04. FIRST AID MEASURES
    Inhalation:
    Persons suffering from lack of oxygen should be removed to fresh air. If victim is
    not breathing, administer artificial respiration. If breathing is difficult, administer
    oxygen. Obtain prompt medical attention.
    Eye:
    Contact with liquid or cold vapor can cause freezing of tissue. Gently flush eyes
    with lukewarm water. Obtain medical attention immediately.
    Skin:
    Contact with liquid or cold vapor can cause frostbite. Immediately warm affected
    area with lukewarm water not to exceed 105°F (40°C).
    Ingestion:
    None.
    Notes To Physician:
    None.
    05. FIRE FIGHTING MEASURES
    Flash Point:
    -156F (-104C)
    Autoignition:
    842F (432C)
    Flammable Limits - Lower:
    2.2%
    Flammable Limits - Upper:
    9.5%
    Extinguishing Media:
    CO2, dry chemical, water spray or fog for surrounding area. Do not extinguish until
    propane source is shut off.
    Fire Fighting Instructions:
    Evacuate all personnel from danger area. Immediately cool container with water
    spray from maximum distance, taking care not to extinguish flames. If flames are
    accidentally extinguished, explosive re-ignition may occur. Stop flow of gas if
    without risk while continuing cooling water spray.
    Fire And Explosion Hazards:
    Propane is easily ignited. It is heavier than air, therefore, it may collect in low areas
    or travel along the ground where an ignition source may be present. Pressure in a
    container can build up due to heat, and it may rupture if pressure relief devices
    should fail to function.
    Hazardous Combustion Products:
    None known.
    Sensitivity To Static Discharge:
    Possible, container should be grounded.
    Sensitivity To Mechanical Impact:
    None.
    06. ACCIDENTAL RELEASE MEASURES
    Evacuate:
    Evacuate the immediate area. Eliminate any possible sources of ignition, and
    provide maximum explosion-proof ventilation. Shut off source of propane, if
    possible. If leaking from cylinder, or valve, contact your supplier. Never enter a
    confined space or other area where the concentration is greater than 10% of the
    lower flammable limit which is 0.22%.
    07. HANDLING AND STORAGE
    Storage:
    Specific requirements are listed in NFPA 58. Cylinder storage locations should be
    well-protected, well-ventilated, dry, and separated from combustible materials.
    Cylinders should never knowingly be allowed to reach a temperature exceeding
    125°F (52°C). Cylinders of propane should be separated from oxygen cylinders or
    other oxidizers by a minimum distance of 20 ft., or by a barrier of non-combustible
    material at least 5 ft. high having a fire resistance rating of at least ½ hour. Full and
    empty cylinders should be segregated. Use a first-in, first-out inventory system to
    prevent full containers from being stored for long periods of time.
    Cylinders should be stored upright with valve protection cap in place and firmly
    secured to prevent falling or being knocked over. Protect cylinders from physical
    damage; do not drag, roll, slide or drop. Use a suitable hand truck for cylinder
    movement. Post "No Smoking or Open Flames" signs in the storage areas. There
    should be no sources of ignition. All electrical equipment should be explosion proof
    in the storage and use areas. Storage areas must meet national electric codes for
    class 1 hazardous areas.
    Handling:
    Propane is heavier than air and may collect in low areas that are without proper
    ventilation. Leak check system with leak detection solution, never with flame. If
    user experiences difficulty operating cylinder valve, discontinue use and contact
    supplier. Never insert an object (e.g., wrench, screwdriver, pry bar, etc.) into valve
    cap openings. Doing so may damage valve, causing a leak to occur. Use an
    adjustable strap wrench to remove over-tight or rusted caps. Non-sparking tools
    should be used. Never strike an arc on a compressed gas cylinder or make a
    cylinder a part of an electrical circuit. Electrically bond and ground cylinder when
    transferring liquid product. For additional precautions in using propane see Section
    16 - Other Information.
    08. EXPOSURE CONTROLS - PERSONAL PROTECTION
    Engineering Controls:
    Ventilation:
    Natural or mechanical to prevent accumulation in worker's breathing zone above
    exposure limits. (See Section 2).
    Personal Protective Equipment (PPE):
    Clothing:
    Cotton Clothing is recommended for use to prevent static electric buildup.
    Glasses:
    Safety glasses are recommended when handling cylinders.
    Shoes:
    Safety shoes are recommended when handling cylinders.
    Gloves:
    Work gloves are recommended when handling cylinders.
    Respirator:
    None required in general use.
    Emergency Use:
    Self-contained breathing apparatus (SCBA) or positive pressure airline with mask
    are to be used in oxygen-deficient atmosphere. Respirators will not function.
    Before entering area, you must check for flammable and oxygen deficient
    atmospheres.
    09. PHYSICAL AND CHEMICAL PROPERTIES
    Physical State:
    Gas
    Color:
    Colorless
    Odor:
    Unodorized propane has a slightly sweet odor. If an odorant has been added it will
    have a strong unpleasant odor.
    Molecular Weight:
    44.097
    Boiling Point:
    -43.67°F ( -42.04°C) @ 1 atm
    Specific Gravity:
    1.5223 At 70°F (21.1°C) @ 1 atm, Air = 1
    Freezing/Melting Point:
    -305.84F (-187.69C) at 1 atm
    Vapor Pressure:
    109.73 psig, (756.56 kPa) at 70°F (21.2°)
    Vapor Density:
    0.110 lb./cu ft (1.1.77kg/CuM), At 70°F (21.1°C) @ 1 atm
    Water Solubility:
    .065 Vol./Vol. At 100° F (37.8°C)
    Expansion Ratio:
    1 to 290 at 70°F (21.1°C)
    pH:
    Not applicable
    Odor Threshold:
    1800 mg/CuM
    Evaporation Rate:
    Not Applicable - Gas
    Coefficient Of Water/Oil Distribution:
    Information not available
    10. STABILITY AND REACTIVITY
    Chemical Stability:
    Stable
    Conditions To Avoid:
    None.
    Incompatibility With Other Materials:
    Oxidizing agents.
    Hazardous Decomposition Products:
    None.
    Hazardous Polymerization:
    Will not occur
    11. TOXICOLOGICAL INFORMATION
    Other Studies Relevant To Material:
    Propane is nontoxic and is a simple asphyxiant, however it does have slight
    anesthetic properties and higher concentrations may cause dizziness.
    Irritancy Of Material:
    None.
    Reproductive Effects:
    None.
    Teratogenicity:
    None.
    Synergistic Materials:
    None.
    Sensitization To Material:
    None.
    Mutagenicity:
    None.
    12. ECOLOGICAL INFORMATION
    ECOTOXICITY:
    No adverse ecological effects are expected. Propane does not contain any Class I
    or Class II Ozone depleting chemicals (40 CFR Part 82). Propane is not listed as a
    marine pollutant by DOT (49 CFR Part 171).
    13. DISPOSAL CONSIDERATIONS
    Waste Disposal Method:
    Do not attempt to dispose of residual or unused quantities. Return cylinder to
    supplier.
    Residual product within process system may be burned at a controlled rate, if a
    suitable burning unit (flare stack) is available on site. This shall be done in
    accordance with federal, state, and local regulations.
    14. TRANSPORT INFORMATION
    DOT/IMO Shipping Name:
    Propane
    HAZARD CLASS:
    2.1 (Flammable gas.)
    Identification Number:
    UN 1978*
    PIN:
    1978
    Product RQ:
    None.
    Shipping Label:
    Flammable Gas.
    Placard (When Required):
    Flammable gas.
    Special Shipping Information:
    Cylinders should be transported in a secure position, in a well ventilated vehicle.
    The transportation of compressed gas cylinders in automobiles or in closed-body
    vehicles can present serious hazards and should be discouraged.
    *For domestic transportation only: The identification number UN 1075 may be used
    in place of the identification number UN 1978. The identification number used
    must be consistent on package markings, shipping papers, and emergency response
    information (Special provision 19 from 49 CFR 172.101).
    TOP OF THE PAGE
    WOULD YOU LIKE MORE INFORMATION OR LEAVE A MESSAGE
    ©INTERNATIONAL INDUSTRIAL GASES LIMITED. All rights reserved.
    /forums/images/graemlins/grin.gif
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    interesting that the autoignite temp is lower on propane than some of the temps that a catalytic converter can get to. doh... rock shears off propane regulator... propane spills out... next thing ya know you're saying "hey, u smell something... 2 secs later... BOOOOOOOOM!!!!! /forums/images/graemlins/shocked.gif
    j
  10. wild-will
    Aug 21, 2003
    185
    Oak town WA
    Hey jeffro calm down it isnt as dangerous as you think. Why would the guys on trucks put it in there truck if it was so dangerous and plus i have never seen or heard of fatality's or trucks blowin up
  11. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    I Ain't Skeered!! Hell At the bus shop where I work we work with liquified natural gas. Pretty cool stuff. Liquified at 200 something below zero. Kinda cool to play with but you don't want to get much on your skin. It'll freeze-dry you.
  12. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    i agree that you dont hear about propane rigs blowing up all the time. At the same time, not to many hardcore 4x4s run propane. As far as being flammable goes, propane is one of the more dangerous gases that are commonly available. If mixed with air in the right proportions and then ignited, say goodnight, cause it wont just be a little flame, it'll be an explosion.
    all of that said, some peeps run it and it seems to work for them so charge on. I wouldnt run it, but thats my rig. On your rig you can run whateva u want. /forums/images/graemlins/laugh.gif
    j
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Maybe not too many rigs use propane, but I've seen some hardcore TTC compeditors that do.
    What kind of carb do you need to use? I checked out the propane site but he got his for free so I'm just not seeing it.
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    from what I have heard you get less power. Less mileage. it costs less per gallon but not that much less. Availability is far less especially for a down the highway venture. All things concerned its a bad idea. This is what I have been told. Years ago propane was considerably cheaper which help to offset the mileage loss.
