Anyone have 14 bolt disc brake plans? ---Got some, have questions now.---
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Sep 15, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I was wondering if anyone has plans for 14 bolt disc brake brackets. I have access to a lazer that will cut metal. Plans in either CAD or just something with dimensions would be great. Any anyone help? Thanks!
    __________
    Well I got some designs. I have a couple of questions. First off the holes for where the calipers mount needs to be 7/16 right?
    But the hole on the bracket doesn't need to be threaded does it?
    How thick is the spacer on most designs? The design I got says to use 80-90 ford rotors and 72-76 2WD chevy calipers, will this bracket work with the K20 rotors and calipers? Any help is appriciated. Thanks!
  2. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Re: Anyone have 14 bolt disc brake plans?
    anyone?
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    You can buy the plans on ebay for 20 bucks! /forums/images/icons/cool.gif
  4. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    where on ebay? I couldn't find them.
  5. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    I saw them on eBay a while back but haven't seen them in a while. Search for " 14 bolt ".
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    does your email accept images?
  7. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
  8. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I got some plans. I have questions. See original post, it is edited.
  9. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    The hole needs to be threaded that is what holds the caliper on, as far as the type of caliper the 1/2 and 3/4 tons are all the same even for vans from 73 to 91.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have heard that if you use the Ford rotors, the center hole must be machined out slightly larger to fit the bearing hub.
    I have also heard the Ford rotors sit at a different depth than the Chevy rotors, hence the need for the spacers to protrude the bracket out to the proper working space.
    Just not sure exactly if the Ford rotors require any spacers or not.
    If I were you, I would make the spacers and use the GM rotors. Easier when you need to get the parts and not have to try to "remember" to get the parts from a Ford. /forums/images/icons/wink.gif
  11. bogginnut
    bogginnut Registered Member
    Jan 6, 2002
    82
    Jacksonville, Florida
    I bought a set of those $20 CAD drawings on ebay, and don't have access to a lazer cutter. Figured I would find someone who did eventually. Want to do some horse tradin? Ooops, just re-read your original post, I see you got your plans. I gotta check the site more often.
  12. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    check your mail
  13. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
  14. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    lol this thread is over 3 years old
  15. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    way to resurrect a thread (i think i mispelled that)
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    Noticed that, too. :doah: I didn't even remember making that reply to this thread either. :haha:
