anyone have a 2200 stall?
Discussion in 'The Garage' started by CHEVY 4WD, Feb 22, 2004.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Just wondering if anyone has a 2200 RPM stall converter, and what it shift 1st to 2nd at? /forums/images/graemlins/dunno.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    700r4 from BTO too...
    it shifts fine... now that there's fluid in it.. /forums/images/graemlins/whistling.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The torque converter doesn't affect the shift points of a tranny. /forums/images/graemlins/eek.gif It only affects the engine RPM at which the converter fully engages.
  4. Confedneck
    Nov 1, 2002
    5,236
    so the higher a convertor stalls at wont cause the trans to shift higher in the RPMS??? /forums/images/graemlins/ears.gif
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Nope. It doesn't change anything internal to the tranny. The governor and/or TV cable affect the shift points.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used to run a 2400 stall. Just cruising, it does not make much of a difference. Getting on it is nice as it pulls out of the hole harder. It will not change the shift points as they are above 2200 RPM anyway for WTO.
