Anyone have a 88-98 chevy dually?
Discussion in 'Tow & Trailer' started by willyswanter, Nov 18, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I'm looking at possibly picking up a late 90's crew cab long bed dually for a tow rig once my truck goes on the trailer. But, I'm building a gooseneck trailer now that will be pulled by my truck and the willys will ride the trailer, but what I need to know is the height of the bed on a stock truck? I need to make sure I build enough adjustment into the coupler on the trailer so it will work with my truck and the new one.
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    If you can't find anyone with a dually, I can measure my stock 97 K2500HD. Should be a couple of inches lower.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have a '92 Chevy x-tra cab long bed 4x4 Dually. I am running 33" tires on it.
    The bottom of the rear of the bed sits 34" from the ground. Let me know if you need anything else.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well it makes a big difference if it's 2 or 4wd.
    I can check that for you here on site i have all kind of chevy's just let me know which one.
    /forums/images/graemlins/thumb.gif
  5. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well it depends on what I find. Can you check both? /forums/images/graemlins/thumb.gif
  6. rvreddog
    rvreddog Registered Member
    Oct 14, 2002
    67
    San Antonio Texas
    A lot of the production trailers I`ve looked at are adjustable. That way you don`t have to do cutting welding and fabing if you want to hitch your wagon to another truck. Just a thought. /forums/images/graemlins/cool.gif
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I know, and mine will be adjustable but the couplers are only adjustable about 10". So what I'm trying to figure out is if there is 10" of difference between my truck and a stock truck... If there is more I have to essentially make the coupler bolt on to a flat plate with a series of bolt holes so I can raise and lower it even more. But I don't want to do this if I don't have to so I'm trying to figure it out... Anyone know the measurement???
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Hey jason
    I sent you a PM on NCBD, but the lowest I found was 25" and it was a loaded truck, the emty one was 28" to the ground
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Did you miss my post?
  10. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    why don't you just buy mine and then you'll have it in the driveway to get measurements off of. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif no matter what you do- you CAN NOT beat air ride!!
  11. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Uh, no I didn't but I'm looking for a stock rigs height... If someone knows the height of the stock tires I could figure it out from there... But iceman already got me the info so it doesn't matter anyway. Thanks.
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
