Anyone have a exploded view of a np208 or know how one goes together??
Discussion in 'The Garage' started by 85mudblazin, Jan 30, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I took off the first housing fine but when I took off the main body cover a spring flew out along with a cap type thing and a small bearing with 2 washer things. And is the bottom of the chain supposed to be loose and the top tight?? Can someone help me out here???
    Here are some pics of what I am talking about
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The thrust bearing and the 2 washers should be off the front output shaft. The spring and cap slide over the bar the shifter forks are on.
    Pauly383K10 should have an exploded view if you need it.
    Harley
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    as far as the chain goes, gravity makes the chain the way it is. because the output shaft is not supported with the beaing in the tail shaft, the output shaft is being pull over with the weight of the chain causeing it to be loose.
    i always pull the fill plug when its fully assembled and push the chain with my finger to check it.
    you can hold a few links between your hands and pull on it and compress and see how much the pins move. you shouldn't have any noticable movement in a perfect chain
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok good thanks yall :)
  5. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    So does the cap slide on the bar first or the spring?? and does the spring go down inside the cap or sit on top of it??
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The spring then the cap. The thrust bearing sandwaches between the 2 washers.
    Harley
