Anyone have a list of parts for a Dana 60?
Discussion in 'The Garage' started by ChevyCaGal, Jul 9, 2002.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Hey.... does anyone have a link to a site (or on here for that matter) that shows a complete list of parts of a Dana 60 (front axle)? Also what about a good book that talks about rebuilding one piece by piece? I keep seeing parts for sale really cheap all over the place and was wondering if it's possible to buy up all the parts required and build one? Over the next 2 years or so I'd like to get this stuff and build one just to learn about it... if I need it then great I will install it, if not then I will sell it... thanks! /forums/images/icons/smile.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  3. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Thanks Michael.... I'll get to looking. For now I have no idea where I would start. At the very least it'd be a good learning experience even if I don't ever use it!
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Wasn't the D60 manual posted on the main site? /forums/images/icons/confused.gif
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Ruthiford sent me this a while ago
    2. 700014,brg&seal kit for spildel/stub axel
    2.706395x, lower king pin kit
    2.41886, cone for uper king pin
    2.5-332x U joints (the spicer soid core)
    2. 3-82-871 35 spline spicer stub axels
    1.Warn pn.38786 35 spline locking hubs
    2.36487 tube seals(in the tube to seal around axel shaft)
    1 set wheel brgs(I like Auto zone they sell timkin brgs and seals)
    1 set calipers and pads
    and a master brg kit for the diff (should include the pinnion seal and cover gas-kit
    and you might check localy or cal Rand's ring a pinnion!
    not everything---but it will help---you can use the part #'s to find out how much they are new and buy the used stuff accordingly
    Dan
  6. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I just found my word document that has that info
    with image showing what and where each part is.
    does your email accept 263K file?
    001 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    002 GM_60F(TAB) TAB BILLS
    003 34643 SLINGER - PINION BEARING INNER
    004 706046X INNER PINION BEARING KIT
    005 706375X KIT - DIFF & PINION ADJ SHIM
    006 30982 BAFFLE - PINION BEARING
    006 706359X KIT - PINION BRG ADJ SHIM
    008 706045X OUTER PINION BEARING KIT
    009 42737 THRUSTWASHER - BEARING
    010 42449 SEAL - PINION
    011 2-4-3801X END YOKE ASSEMBLY (INC 10)
    012 34592 SLINGER - END YOKE
    013 30275 WASHER - PINION NUT
    014 30271 NUT - PINION
    014 GM_60F(VAR) VARIABLE PARTS TABLE
    015 GM_60F(VAR) VARIABLE PARTS TABLE
    016 34822 BOLT - CARRIER COVER (QTY 10
    017 GM_60F(VAR) VARIABLE PARTS TABLE
    018 34687 GASKET - CARRIER COVER
    020 48632-1 BOLT - DIFFERENTIAL BEARING CA
    021 706047X DIFFERENTIAL BEARING KIT
    022 706378X KIT - DIFF BRG ADJ SHIM
    023 Not Sold Separately NO MASTER RECORD
    024 30266 BOLT - DRIVE GEAR (QTY 12)
    026 34367 PINION
    027 34729 THRUST WASHER
    028 34730 THRUST WASHER
    029 44810 LOCK - DIFFERENTIAL SHAFT
    030 30263 DIFF SHAFT
    031 36487 SEAL & GUIDE TUBE
    031 706395X KIT - KING PIN PARTS
    032 620058 SEAL - KING PIN - UPPER
    033 37305 RETAINER - GREASE
    034 706150X KIT - BEARING - KING PIN - L
    035 41777 SEAL - OIL
    036 31026-1 SCREW - STOP
    037 500381-3 NUT - HEX SLOTTED
    037 500381-3 .375-24 HEX NUT
    038 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    039 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    040 500175-1 FITTING - LUBRICATION
    041 30875 NUT - HEX TAPERED
    043 38139 ARM - STEERING (LH ONLY)
    043 620132 CAP - KING PIN - UPPER (RH ONL
    044 37307 GASKET - KING PIN CAP
    045 37300 SPRING - PRESSURE
    046 620180 GEAR
    047 41886 BUSHING - KING PIN
    048 37302 PIN - KING
    048 72837X KIT - RIGHT KNUCKLE ASSY (49,
    048 72838X KIT - LEFT KNUCKLE ASSY (50, 5
    049 41893 RIGHT KNUCKLE
    050 41894 LEFT KNUCKLE
    051 37879 BOLT - HEX
    052 37299 CAP - KING PIN BEARING LOWER
    053 500357-13 LOCKWASHER (KING PIN CAP - LOW
    054 500412-13 BOLT - HEX (KING PIN CAP - LOW
    055 GM_60F(TAB) TAB BILLS
    056 37308 SLINGER
    056 700014 KIT - SPINDLE SEAL & BEARING
    056 GM_60F(VAR) VARIABLE PARTS TABLE
    057 37311 SEAL - OIL
    058 37312 SPACER - WHEEL BEARING SPINDLE
    059 620062 SEAL - NEEDLE BEARING
    060 620063 NEEDLE BEARING - SPINDLE
    061 GM_60F(VAR) VARIABLE PARTS TABLE
    062 36880 NUT - BRAKE MOUNTING
    063 48816 SEAL - GREASE
    064 706411X INNER WHEEL BEARING
    065 706074X INNER WHEEL BEARING KIT
    066 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    067 GM_60F(VAR) VARIABLE PARTS TABLE
    068 GM_60F(VAR) VARIABLE PARTS TABLE
    069 GM_60F(VAR) VARIABLE PARTS TABLE
    070 GM_60F(VAR) VARIABLE PARTS TABLE
    071 GM_60F(VAR) VARIABLE PARTS TABLE
    072 GM_60F(VAR) VARIABLE PARTS TABLE
    073 GM_60F(VAR) VARIABLE PARTS TABLE
    074 Contact Vehicle Mfg. HOUSING - AXLE SERVICE
    075 35830 GEAR, TRAC-LOK
    075 707083X KIT - DIFF PLATE & DISC (T/L)
    076 Not Sold Separately NO MASTER RECORD
    077 Not Sold Separately NO MASTER RECORD
    078 Not Sold Separately NO MASTER RECORD
    079 40835 CLIP - DIFF CLUTCH RETAINER
    080 Not Sold Separately NO MASTER RECORD
    900 GM_60F(TAB) TAB BILLS
    901 GM_60F(TAB) TAB BILLS
    902 GM_60F(TAB) TAB BILLS
    903 GM_60F(TAB) TAB BILLS
    904 GM_60F(TAB) TAB BILLS
    905 GM_60F(TAB) TAB BILLS
  8. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I have America Offline.... so I think so.... is it this list here? If so then I can cut and paste and save it to word and save you an email...
  9. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Thanks... I was doing a search and never saw it... I knew I saw one but didn't realize it was right there in front of my freaking face... /forums/images/icons/tongue.gif /forums/images/icons/shocked.gif /forums/images/icons/grin.gif
  10. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    MJ, I would appreciate a copy of that word.doc that you mentioned. Please email to bill@a-tron.net
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    is everyone without the email notification or just me?
    on the way...
  12. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    same here, no notification.
  13. 45acp
    Jan 3, 2001
    695
    Tucson, Arizona
    MJ, Received the work.doc and its great. Thanks a lot.
  14. JustCuz
    JustCuz Registered Member
    Mar 23, 2002
    76
    Michigan
    Hey MJ you wanna send that my way too?
    I'm in the middle of putting mine back together.
    Thanks alot,
    robmo4@attbi.com
