Anyone have a means of checking a casting # v/s application?
Discussion in 'The Garage' started by uglychevyZZ4, Sep 17, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Anyone have a means of checking a casting # and what it goes on, etc...? I wanna know if my jimmy's engine is the original or whats the scoop for ordering rebuild parts. I also wanna check the heads. lemmie know and ill get them for you if you have this means.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I dont think the casting # will tell. You need to look at the number on the block behind the alternator. The casting number will put you in the ballpark along with the head casting numbers. Post them and I'll look them up for you.
    Somebody here has a book that decodes the numbers behind the alternator. They will tell you exactly what it was for.
  3. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    let me know what you got and i will tell you what you have for an engine and heads and if they are in the correct year for your truck
    thanks
    travis
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    77 jimmy
    head #'s are 3998991 ( also says GM71)
    im lookin for the block numbers now, brb and BTW your link dosent work /forums/images/icons/wink.gif
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    heads #3998991....72-73...307/350......75cc chambers
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Cool, maybe i'll use my humpy's instead when i rebuild it /forums/images/icons/wink.gif engine # comin up.
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm logging off.. try this link:
    mortec
    Good luck
  8. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    WOW that link is the ShiZ-Nit!! /forums/images/icons/shocked.gif it has everything!
  9. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    that is a pretty cool site.thanx
