Anyone have a push bar on there k10 or K5?
Discussion in 'The Garage' started by FarmRig, Jun 21, 2006.
  1. FarmRig
    FarmRig Guest
    Yes, i was at the junkyard and found one on a 79 or 78 k10. It was bolted through 2 holes on the front of the frame. One is howled out and the other is a regular hole. The regular hole lines up with the push bar wile the other one does not. Anyone have pics of what they did to get it to fit? Thank you. Iam thinking i might have to drill another hole in the push bar to line up to the 2nd hole in the frame.
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I don't see any reason why you shouldn't drill another hole in the push bar and bolt it up.
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Here is my push bar, if that is what you are looking for.
  4. FarmRig
    FarmRig Guest
    Alright good thanks.
  5. diesel4me
    Jul 24, 2003
    17,573
    943
    Massachussetts
    what year???
    The frame "horns" where the bumper brackets attatch changed slightly in the 81 to 87 trucks--so if your mounting a pre-1980 push bar,you'll have to drill another hole,or make up a plate to allow it to bolt to the frame rail..no biggie really..it'll work,just use 1/4" or thicker steel if you need to make a bracket,so it will be beefy enough ...:crazy:
