Anyone have a winch on there car trailer?
Discussion in 'The Garage' started by 90blzr, Aug 25, 2003.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Gonna be getting another trailer real soon and would like to put a winch on the front. How do you guys wire them up? Do you have a seperate battery on the trailer just for the winch? Or are they wired to the tow vehicle some how?
    What size winch are you running/recommend?
    Any pics of how the winch is mounted?
    Thanks/forums/images/graemlins/thumb.gif
  2. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    One of the guys at my work has a really slick setup - he has a Warn Multi Mount with the Quick Connects - and he built a mount for the winch in the trailer too - the connection from the winch is long enough that it still reaches the rear truck connection even when mounted on the trailer - that's how I'd do mine.... /forums/images/graemlins/thumb.gif
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Any chance you can get some pics and how he did it?
  4. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Well his car trailer is out in tim-buck-too - so let me try and explain it...
    All he did was weld a receiver plug at a 90 degree angle to some more square tubing going vertical and weld that assembly into the trailer floor - at the very front of the trailer bed. It's a little bit off the floor - which really helps for loading stuff, as the winch cable doesn't drag on the trailer deck.
    It's not really pretty - but it works great!
  5. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i have a ramsey 8000 that i use for my rear winch when wheelin fits in my reciever on the blazer.so i got another truck reciver hitch and attached it to my car trailer for the winch...i have 25ft jumper cables wired to my winch to power it..it also works on anybodys vehicle with a reciever hitch /forums/images/graemlins/thumb.gif
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I have a boat winch on my trailer. I got it used and I forget the rating, but it pulls my Blazer up on the trailer and in between the fenders just fine. I fastened a seperate marine battery to the bed of my Ram that I charge the night before a run. I've also used this battery to jump other trucks too, it comes in handy
  7. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    I just bought one of those batteries that have both posts and screw in connectors. Then I got some double ought welding wire and two male welding connectors and the two female as well. Put the two male connectors on the wires comin from the winch and two female on the wires leadin to the battery posts. What this does is make a direct connection straight from the battery to the winch. Quick and dirty. Good luck and such.
    Allan
  8. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I use a warn 8274 on mine, mounted it to the front of the deck so it goes up with the tilt. I just use the one battery and have a hot wire from the truck to keep the battery charged. This and a steel deck makes it handy for loading junkyard treasures (don't need no wheels...)
    &lt;p&gt;
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    /forums/images/graemlins/grin.gif
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    thats how i will be doing mine as well /forums/images/graemlins/thumb.gif i have the winch just don't have the trailer yet /forums/images/graemlins/eek.gif
