anyone have an exploded diagram of a 98 tahoe IFS?
Discussion in '1992-Present Chevy & GMC models' started by spartan4x4, Dec 18, 2004.
  1. spartan4x4
    spartan4x4 Registered Member
    Nov 30, 2004
    18
    SC
    the differential axle bearings are pretty worn in this IFS chunk, and since the pinion seal is leaking i'm going to rebuild the unit, all except the gears. does anyone have a good exploded diagram that breaks this unit down? TIA
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    NO sorry. Its pretty straight forward, It splits open and the carrier comes out. Have fun, tey can be a real PITA and sometimes thay can be easy. To get the carrier races out, if you heat it up (like put it in a parts washer) and then slam it on the ground they should fall out, if not, you can weld a bead on the race then slam it on the gorund, it should fall out. The pinion races are hard to get in and out too, along with the axles.
  3. spartan4x4
    Nov 30, 2004
    18
    SC
    thanks for the info, but i'm not changing the carrier bearings or any of that, i'm changing the small needle bearings that the axle shaft rides inside of.
  4. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    HAHA, I am an idiot. Sorry.
