Anyone have any super low buck off road tricks? Any pics?
Discussion in 'The Garage' started by moturbopar, Feb 9, 2006.
  1. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    Hi all, I am getting ready to start working on the jimmy. I am trying to build this on a super tight budget. I was wondering if you guys can post pics and descriptions of your cheap innovations, that might help me build this thing.
    Stuff like spring swaps and all the well known stuff I can do a search for.
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Here's a good nearly free mod- move your front shackle hangers and build custom length shackles. By far one of the best modifications that i've done to my truck.
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    browse ebay, bargains can still be had on there if you take the time to search and look for things in odd places, such as listed in wrong area, and incorrect descriptions.
    for example, i just got a 1410 yoke for my D60 for $25, and it is a brand new takeoff unit.
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    air down?!
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    trim the fenders and ditch as much of the body as-is possible. low weight = high perf.
    j
  6. goldwing2000
    goldwing2000 Guest
    Flip the spacers on your trans cross member to drop the t-case down and get a better driveshaft angle.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I always start doing something that will be cheap. I always end up spending waaaay more than I ever thought.
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If you ain't got money for a locker...click your parking brake in slowly when you get stuck. Brakes will slow the spinning wheel and send it to the one sitting still....that's gotten me out of a few situations....
  9. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    Take your sway bar off its free and helps alot.
  10. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    move the battery to the rear? I'm planning on doing this too. My build is definitely a budget build.
    thanks,
    James
  11. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Frame brace.
  12. goldwing2000
    goldwing2000 Guest
    Damn right.:waytogo:
  13. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Buying stuff used will help alot. The spring swaps for the most part are not that cheap because they require you to run crossover steering.
    Heres my biggest tip to keep the cost low: "If it aint broke, dont fix it"
  14. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    couple things i can think of one maintain it so that you dont have to spend money fixin so much and 2 take the front sway bar out for better flex and 3 was for an earlier post about moving the battery to the rear well not such a great idea due to the gases that a charging battery can produce.
  15. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I've got lockers but that is one of the best I ever heard.:D
  16. goldwing2000
    goldwing2000 Guest
    'Splain that?
    Are you saying that putting in lift springs requires crossover?
    Or something else?
  17. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Run all of you drivetrain vents into the engine compartment or high as possible to keep water out of your lubes. Use marine bearing grease on wheelbearings to prolong their lives in watery situations. Use the board classifieds, trust me it pays when your broke/badly bent.
  18. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Can marine greese handle the heat requirements for wheel bearings? Those little bastards take a beating...
  19. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    x2.
  20. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    IMO if you want to steer then yes. Its amazing how much more sucky the stock steering gets once you add lift springs. The other thing is if you move your axle forward or do a 52" spring swap you going to have to go to crossover due to the stock draglink being too long.
