Anyone have custom tube bumpers on their Blazer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjblazer, Apr 28, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    If so, what are the specs, and do you have the 2 inch receiver hitch in the back? and anyone got pics of what they look like? Thanks
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I will if in about a week or so.
    Dunno till I get it done tho'./forums/images/icons/smile.gif
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I will in about a week or so.
  4. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    check the link in my sig.
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    yeah, check my webshots. 2x4 Square Tube /forums/images/icons/wink.gif
  6. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
  7. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
  8. CK5
    May 19, 1999
    21,623
    701
    CO
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I will post some pics of mine tonite for you. Mine, however, are not custom. They are made by smittybilt. Of course, got them over 8 years ago. I don't know if they still make them. wOrk great for me because they sit higher then the factory bumper (cover gap from body lift), have a nice little diamond aluminum "platform" and my frame-mounted reciver hitch sits snuggly below it all.
  10. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Hey Laketex
    How do you pin the receiver in that hitch? Can't seem to find a pin hole. And how did you fab the rings on there (what meterials and such) ?
  11. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
  12. laketex
    6,220
    North Texas
    The recievers are mounted flush so I could use the stock pin holes. I just welded the outside support ring solid to the tube and fit it in there. Hole stayed the same when put through the 4x2 tube only it's on the backside. Got them at:
    <a target="_blank" href=http://www.redneck-trailer.com>www.redneck-trailer.com</a>
    As for the shakles, I bought those...i've found some things are cheaper to have someone else make. They were only a couple dollars each and I got them through buyers hardware...I cant seem to find a web address for that though.
  13. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Here's mine. <a target="_blank" href=http://community.webshots.com/album/25499947XxjDjyPxVb>http://community.webshots.com/album/25499947XxjDjyPxVb</a>. It's 2x4 3/16" wall box tube along the back and wrapped around the side. Dirt simple and has suported the weight of the truck without flexing at all. The receiver is welded into the tubing so it doesn't hang down below the bumper at all.
  14. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Here's mine. I've got a 4" lift and from the bottom of the bumper to the ground is a little over 36" and I do have a reciever hitch on it.
    (they're thumbnails so click on them to get a bigger view)
    http://www.bluefox.tv/~iroc/rearbumper.html
    and the tire carrier (which I'm doing a little modification to)
    http://www.bluefox.tv/~iroc/sparecarrier.html
    the carrier on the truck:
    http://www.bluefox.tv/~iroc/flex4.jpg
    I didn't box the one end of the bumper that the carrier swings on and had problems with it. Once I box that end up, it'll be strong. The other day I was yanking a tractor out and taking a running start at it before I hit the end of the rope and the bumper's fine. Scratched some paint off though.
    The tubing is 4x4 square tubing.
  15. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I'll cast my link in here also. I just finished the tire carrier and got it mounted - it fits perfectly!!!
    Pics to follow tomorrow. I need to make 7 more pieces to finished it. It is big and bad - next is the 4" lift.
    <a target="_blank" href=http://www.geocities.com/keywestk5/Bumper.html>http://www.geocities.com/keywestk5/Bumper.html</a>
  16. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Man Muddin I wish you could whip one of those out for me that is SHARP.
  17. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Prerunner style on mine w/2" hitch. The link under my name
