Anyone have initial timing set higher than 12?
Discussion in 'The Garage' started by mrk5, May 17, 2004.
  1. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I was doing some searching on timing here in the forum. I'm curious if anyone is running higher than 12 degrees initial timing. The Demon carb I have recommends 18-24 /forums/images/graemlins/yikes.gif That just seems insane. I know this is going to get a bunch of different opinions, but I'm just curious what they are. /forums/images/graemlins/thinking.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    sure it doesn't mean total advance?
  3. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    What are the specs of the engine and carb? I've got mine at about 22 deg.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Since when does a carb solely determine timing? I wonder why they recommend that? /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif
    There are far too many factors besides a carb that determines timing.......compression ratio, advance curve, cam, octane of gas, engine load etc etc to name a few.
    Strange...... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  5. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    My thoughts exactly.
    I've got a recently rebuilt (as of 4/30) 350, bored .060, should be close to 9:1 compression, CompCam 268H (.454 lift and 218 duration), Thorley headers, Performer intake, MSD Pro-billet distributor, and 625 Road Demon. Plus living at a higher altitude does allow a little more advance, normally I would run 10-12.
  6. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Mine likes to run at 30-32 /forums/images/graemlins/dunno.gif
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so at what initial do you start to see problems or power loss?
    did you just pull the 12* number from a hat or did you tune to that point?
    combustion chamber design and fuel will dictate a bit on timing requirements
    better chambers need less advance IIRC
  8. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    Basically I set it their based on the advice of a mechanic. But the more research I do, the more I find that using one number for all engines is not the best. I plan on using the vacuum method to see how that works. /forums/images/graemlins/thinking.gif
    But yeah, basically I set the timing to 12* and tuned the carb to work with that.
