aNYONE HAVE THEIR LIFT SPRINGS REARCHED?
Discussion in 'The Garage' started by bigjbear, Jul 12, 2005.
  1. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    So how about it? I've got a set of springs I'm thinking of having this done to. I would have about 2" of free arch added. It probably doesn't matter but, they are 4" Skyjacker Soft-rides, 5 leaf pack and a little over 5 yrs old.
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Wouldn't that make them shorter? :thinking:
  3. carpeonnel
    carpeonnel 1/2 ton status
    Jul 12, 2005
    1,184
    Albany, Georgia
    don't do it. I rearched some springs and they will give you an awful ride
  4. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Yep, but they are allready longer than a stock spring, and I'm running a longer shackle, so I doubt that it will be an issue.
  5. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Were they lift springs? Was the bad ride on the street?
  6. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    Springy
    Hay just do it you might like the springs ,I had to use a cumalong to put the bolt back into the end of one end but they worked good
  7. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    rearching isn't worth it... they will slowly but surely settle back to whatever height they are now and you'll be out whatever $ you sunk into them. Be cheaper to replace them.
    j
  8. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I gotta agree with that. I did my stock front 1 ton springs twice. Each time they lasted about 6 months and settled right back to their original height.
    Eric M.
  9. 78Buford
    78Buford 1/2 ton status
    Apr 1, 2005
    264
    Ohio
    A while back, I had a broken (stock) main leaf spring, in the front. I considered buying new lift springs, but decided against it because I couldn't get them in the factory Mil-Wrap design......and when mine broke, the Mil-Wrap was the difference between driving it home, and towing it home.
    I had two leaves added to a spare front spring pack, and this required re-arching the main leaf. The re-arching generally goes away, as Jekbrown mentioned. However, the extra springs in my pack should minimize this.
    In short, re-arching the springs for lift (without adding leaves) is not a permanent solution.
    Roy
